Thread: How do I create a section/perspective?
    Active Member photography67836's Avatar
    2003-08
    Abbotsford, BC, Canada
    64
    Default
    I have adjusted view range settings and haven't found anything to give this effect. When I rotate the model in real time in a radiosity view, I notice that the model pieces hovering in front of the camera are being cut off nicely, but they are 'hollow'.
    Is it possible to use a cut plane in front of the camera, with solid model pieces showing? I would like to show a room interior from the outside of the building.
    Thanks
    Jason Brown
    photographer / designer
    www.revivalartsstudio.com
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: How do I create a section/perspective?
    go to a 3d view, turn on section box under view properties, adjust as required, now create a new camera view from a floorplan or site plan, then under the rendering tab/settings there is a choice to use section box from view, pick the 3d view. then render
    (Ed Note: Make sure you are in a Shaded view. The section box does not affect wireframe or hidden line modes)
    Scott D. Brown, AIA
    BECK
  1. Section Box in perspective
    By tklein.208994 in forum Revit - Rendering
    Last Post: 2009-04-02, 03:26 PM
  2. Section Box in Perspective
    By sbrown in forum Revit Architecture - General
    Last Post: 2009-03-03, 06:55 PM
  3. Section perspective? is it possible?
    By vivace_rahl in forum Revit Architecture - General
    Last Post: 2006-08-05, 12:05 AM
  4. section perspective controls?
    By skpark in forum Revit Architecture - General
    Last Post: 2004-11-17, 11:44 PM
  5. Perspective Section
    By Arthur Gunawan in forum Revit Architecture - Wish List
    Last Post: 2004-09-14, 04:59 PM
