Results 1 to 1 of 1
Thread: CM214-2L: Creating the World's Greatest AutoCAD
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default CM214-2L: Creating the World's Greatest AutoCAD
    Instructors: Colleen Klein with Randy Brunette, ROB HOWELL, John Jordan
    Class Description: Explore setting up your templates in AutoCAD 2010 with special focus on advanced use of layers. Your start setup holds one of the biggest impacts in the success of your drawing productivity. Make powerful templates and learn to avoid common pitfalls. You will define layers, layer overrides, and layer filters. You will set up styles for annotative dimensions and text. You will set up basic title blocks and viewports with intelligent labels. Once your template is complete, you will create a drawing from it. You will test your dimensions and text to see if they work. You will learn the workflow for taking nonstandard drawings and testing them against your template. You will also learn effective methods to change existing drawings to comply with your new drawing standards. Bring a flash drive to take your customized template back to your home or office.
  1. ED205-2: The World’s Greatest Training Secrets Revealed!
    By Autodesk University in forum Education
    Last Post: 2013-05-05, 02:37 AM
  2. ED13-1: The World's Greatest Training Secrets Revealed!
    Last Post: 2013-04-17, 04:06 AM
  3. ED12-1: The World's Greatest Training Secrets Revealed!
    Last Post: 2013-04-08, 06:58 PM
  4. ED34-1: The World’s Greatest Training Secrets Revealed!
    Last Post: 2013-03-30, 02:01 AM
