Thread: Exporting 3d to Autocad, taking too long
    2003-08
    Tijuana
    225
    Default Exporting 3d to Autocad, taking too long
    Just curious if you can give an idea of how long should it take for revit to export the whole model (3d geonmetry) to autoacd format. The revit is about 12mg. It already took 1/2 hour, and doesn't seem to be near completion.
    Thanks,
    Carlos
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    Default Re: Exporting 3d to Autocad, taking too long
    Depends on the complexity of the model. Are you exporting 3d toilets, sinks, counters, etc. or just the exterior? Also if there is a dwg turned on in the revit model that will mess things up.
    Scott D. Brown, AIA
    BECK
    All AUGI, all the time BillyGrey's Avatar
    2004-04
    in a calm assertive state
    638
    I have exported 20-30 meg projects fully modeled that usually only take a couple of minutes (never timed them)...That's out of a 3d view into a dwg format.
    I could stop if I wanted to Exar Kun's Avatar
    2003-10
    Canberra, Australia
    256
    I just had this problem today. It occured when I exported a model that had a section box turned on. The same model without the section box exports in no time but with it turned on it took 20 minutes. Also ended up with some odd results. I don't suspect I'll be trying that again!
  1. Enabling Worksharing problem: taking long time ???
    By ACE001 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2011-02-02, 10:50 PM
  2. Macro taking a long time to run
    By drodrigues in forum Revit - API
    Last Post: 2009-06-15, 09:01 PM
  3. Drawings taking to long to send to 1050C plus plotter
    By kimlance in forum AutoCAD General
    Last Post: 2009-03-20, 10:42 AM
  4. Pasting taking to long
    By cstephensen in forum AutoCAD Mechanical - General
    Last Post: 2008-08-25, 07:32 PM
  5. Replies: 0
    Last Post: 2008-05-15, 01:04 PM
