Thread: 3d polylines
    2009-11
    Raleigh, NC
    943
    Default 3d polylines
    What is the best practice for adding 3d polylines to a surface?
    2005-05
    IL
    103
    Default Re: 3d polylines
    Quote Originally Posted by tim_newsome View Post
    Tim, in my experience I would recommend first converting them to Feature Lines as the editing tools area great. You can convert existing objects to Feature Lines from the Home Tab, Feature Line, Create Feature Lines from Objects. Pick all of your 3D polylines, pick a style and if you want to erase your original objects or not. Then you can highlight all of the feature lines you just created, right-click and pick Add to Surface as Breakline. Another route would be to open up the definitions section of your surface in the Toolspace and you can right click on breaklines and add them that way.
    If you choose not to convert them to Feature Lines, you can still add them to a surface as breaklines using the Toolspace method.
    Hope that helps!
    Mike Pollock
    Project Designer
    Farnsworth, Inc.
  1. Polylines with arcs to polylines with segments
    By randyspear in forum AutoCAD General
    Last Post: 2009-04-15, 06:22 PM
  2. Replies: 7
    Last Post: 2008-02-22, 04:13 PM
  3. How to change LW PolyLines to 2D PolyLines
    By Lions60 in forum AutoLISP
    Last Post: 2007-07-13, 05:58 PM
  4. How to convert 3D Polylines to 2D Polylines
    By GreyHippo in forum AutoLISP
    Last Post: 2007-01-04, 05:32 PM
  5. AutoCAD polylines to 3d polylines
    By neil_morrish in forum AutoCAD General
    Last Post: 2004-07-22, 10:40 AM
