Thread: AutoCAD 2014, File with image will not print.
    2011-03
    East Hampton, NY
    32
    Cool AutoCAD 2014, File with image will not print.
    Hi All, Can someone help with this one.
    Usually we download image/Aerial from Google Earth Pro, place it in a file. Overlay a property border on it in position. then print it. And all goes well.
    But sometimes the file with a image in it will not print. "It processes forever". File never prints. (we have troubleshooted by removing all mention of the aerial in the file, and the file prints) It seems that some aerials from Google are bigger than others or have some corruption in them.
    Has anyone had trouble like this, or solution?
    Thanks
    - John
    2011-03
    East Hampton, NY
    32
    Default Re: AutoCAD 2014, File with image will not print.
    UPDATE >>>>>>>>>>>>>>>
    I have solved my own problem.
    I have "unchecked" >Plot Transparency. and the file processed and printed.
    I hope this helps someone. ....ugh.
    - John
    2001-12
    St. Louis
    5,407
    Quote Originally Posted by ciccseven886331 View Post
    - John
    Thanks for confirming your solution.
    Most of us have found that the best way to find a solution is to struggle through it for days, then finally break down and ask... then the solution jumps out at us within the next 60 seconds. Works almost every time.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2011-03
    East Hampton, NY
    32
    Yes, but, wait until I want to print an aerial,.....with a transparency on it.....then what??
    Cairo - no, not Illinois
    5,069
    Often that's resolvable by changing the format of the image file. If it fails, convert the .jpg format to .png, .pdf, or .tif. Almost always, .png files work better than the other options.
  1. 2014: Can't load PDF file into Autocad 2014
    By lee.johnson in forum AutoCAD General
    Last Post: 2014-02-20, 05:47 PM
  2. 2014: Autocad 2014: file names on the file tabs are missing!
    By mephasm in forum AutoCAD General
    Last Post: 2013-04-29, 07:20 AM
  3. Insert image file (TIFF) into an AutoCAD drawing file
    By snorcisa in forum AutoCAD General
    Last Post: 2007-04-15, 09:51 AM
  4. How to print an Excel file from AutoCAD
    By TobyKanoby in forum AutoLISP
    Last Post: 2007-03-14, 08:07 PM
  5. AutoCAD 2005 TIFF Image files - Image file not valid
    By richard_hamilton in forum AutoCAD General
    Last Post: 2004-09-30, 11:39 PM
