Thread: Line and Curve label tags sequential numbering
    Wish List Administration
    2011-08
    4,581
    Default Line and Curve label tags sequential numbering
    Summary: Line and Curve label tags need to be generated sequentially.
    Description: When adding line and curve labels using the Multiple Segment Label Type, and using [label tag number] for the content of the text, the numbers are not generated sequentially. The line and curve labels always skip numbers at random. The numbers need to be generated sequentially.
    Product and Feature: AutoCAD Civil 3D - Annotate (Civil 3D Labels)
    Submitted By: Roger Crandy on 11/19/2014
    Earth
    9,802
    Default Re: Line and Curve label tags sequential numbering
    I don't find that it skips around in Civil 3D 2015.
    If I start with L1, the next one is L2, and so on.
    Need more information and a step by step example.
    R.K. McSwain | CAD Panacea |
    2011-10
    2
    I am having the same problem. I label a polyline with multiple segments (lines and curves) Table is created as L1 then L3. there is a curve between line 1 and line 3. Curve table starts off with C1 and stays sequential.
  1. 2012: Sequential numbering of parcels between different sites.
    By kenny.gordon409453 in forum AutoCAD Civil 3D - Parcels
    Last Post: 2012-08-13, 10:51 AM
  2. sequential numbering w/ mleaders
    By tomcarver in forum AutoCAD Annotation
    Last Post: 2010-03-17, 02:18 PM
  3. Sequential Numbering
    By RockleyFox in forum Revit Structure - General
    Last Post: 2008-09-15, 08:04 AM
  4. Re-Numbering Curve Tags Civil 3D 2006
    By tchesal in forum AutoCAD Civil 3D - General
    Last Post: 2006-10-24, 06:53 PM
