Thread: Rotate pipe network structure by view orientation
    Wish List Administration
    2011-08
    4,581
    Default Rotate pipe network structure by view orientation
    Summary: When toggled structure rotation will match view orientation of view port.
    Description: Enable a toggle to be able to set the view orientation of a pipe network structure to match that of the view port. Particularly for the plan view display of structures that use a block with a letter designation.
    When enabled a storm drain manhole, for instance, that uses a block with a "D" in the center would always read correctly no matter the view orientation of the view port...even when occuring in multiple view ports with varying view orientations.
    Product and Feature: AutoCAD Civil 3D - Pipe Network
    Submitted By: Scott Mayo on 11/24/2014
    2009-11
    5,688
    Default Re: Rotate pipe network structure by view orientation
    Quote Originally Posted by Wish List System View Post
    1+
    Both [Gravity] Pipe Networks, and Pressure Pipe Networks are greatly lacking the functionality we require in order to use for inclusion in our production plans.
    As a result, we currently use them predominantly use them as a design tool, with exception to being projected into both Profile View and Section Views as needed (Plan Display == No Plot Styles)... For Plan views within our sheets, we still use a COGO Point that properly displays the appropriate Block, and provides the 'Orientation Reference: View' the OP is aptly requesting here.
    Computer Specs:
  1. 2015: Pipe network structure label
    By tott700763 in forum AutoCAD Civil 3D - General
    Last Post: 2015-08-05, 02:33 PM
  2. Pipe Network in Section View
    Last Post: 2014-10-27, 02:50 PM
  3. 2014: C3D 2014 Pipe Network Structure Profile Label Bug
    By cshumake in forum AutoCAD Civil 3D - Profiles
    Last Post: 2013-07-30, 02:38 PM
  4. Pipe Network Structure Top of Casting
    By krystaln776098 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2011-01-26, 01:49 PM
  5. Wye Structure in Pipe Network
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-02-05, 09:05 PM
