Thread: Symbol Manager
    2003-08
    35
    Default Symbol Manager
    We are transitioning from LDD to Civil 3D. LDD had a symbol manager which we used to bring in all of our symbols and details. Any suggestions on how to do that in Civil 3D?
    Cairo - no, not Illinois
    5,069
    Default Re: Symbol Manager
    Design Center, and Tool palettes for OOTB approach
    Or look for a third party Block Manager -- there are probably a couple of thousand out there...
    5,719
    Quote Originally Posted by jbenway View Post
    Loosely related, be sure to also setup the necessary Point Groups (in addition to any dependent Point, and Point Label Styles)... This will allow you to import all of your raw point data, and the appropriate symbols will be used without any manual work per-se.
    To be clear, this does not manage the blocks as is done via Design Center, etc. - only manages COGO Point display (if that makes sense?).
    Cheers
    2011-05
    23
    Use Design Center and navigate to
    C:\ProgramData\Autodesk\C3D 2015\enu\Data\Symbols
  1. Symbol Manager
    Last Post: 2008-02-08, 09:01 PM
