Results 1 to 1 of 1
Thread: AB218-3: AutoCAD Architecture Horizontal Sections
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default AB218-3: AutoCAD Architecture Horizontal Sections
    Instructor: Lauren Stassi
    Class Description: Have you ever had trouble creating a reflected ceiling plan that shows exposed roof rafters in only some of the rooms, or a roof plan that shows overlapping gables? Learn how to use the Horizontal Section tool to capture complex models of roofs, ceilings, and walls in 2D line work for your construction documents. No need to mess with display representations, mask blocks, and hatches! Use horizontal sections to create drawings that accurately depict the cut line, depth, and overlaps for your documents.
  1. AB322-1: Breaking Free of the Plan: AutoCAD® Architecture Sections and Elevations
    By Autodesk University in forum Architecture and Building Design
    Last Post: 2015-08-07, 03:57 PM
  2. AB218-2L: A Quick Spin on Autodesk® Revit® Architecture Curtain Walls
    Last Post: 2014-11-30, 01:13 PM
  3. AB218-4: Maximizing Walls in AutoCAD® Architecture for Elevation Views
    By Autodesk University in forum Building Design
    Last Post: 2013-05-05, 03:25 AM
  4. AB218-3P: Effective Techniques for Large Projects Using Revit Architecture
  5. AB218-1L: A Quick Spin on Revit Architecture
    Last Post: 2013-05-05, 03:24 AM
