Thread: Workpoints/planes from circular edge
    I could stop if I wanted to Ron Oldenbeuving's Avatar
    2004-06
    Lewiston, South Australia
    291
    Angry Workpoints/planes from circular edge
    Create a revolved part. Now try to create a workpoint in the centre of any of the circular edges. These same edges will measure up as having a diameter, but you cant create a workpoint in its centre? Neither can you create a workplane on those circles, despite the fact a circle is a planar object. These same problems also hold true for elliptical adges. Please, Autodesk, are these new issues?
    37
    Default Re: Workpoints/planes from circular edge
    Mr. Ron,
    I created a revolved part to investigate it. I was able to create a work plane on a planar face or a work point at the center of a planar face. As you reported, I was not able to create a work plane based on the circular edge.
    I found two ways around this. You can create a work plane by selecting the transition point on the profile and then the axis of revolution. Inventor will create a work plane through the point and perpendicular to the axis. You may want to stretch the work plane to make it more visible.
    You can also create a work plane that is perpendicular to the axis at some known location on the part. You can create work planes based on that work plane, using the dimensions from the revolved sketch to define the distance between the planes. If the sketch is visible while you create the work planes, you can simply click on the sketch dimension to assign it to the work plane definition.
    2004-06
    291
    Thanks Bob. I'll keep those in mind in future, but as you wrote, these are only workarounds, that add extra work where it really shouldnt be necessary.
  1. 2010: 3DCLIP: Circular objects beyond clipping planes only appear during plotting?
    By bblain in forum AutoCAD 3D (2007 and above)
    Last Post: 2012-06-26, 01:08 PM
  2. Reference planes work planes and levels best practice
    By ree.espinoza in forum Revit - Platform
    Last Post: 2010-08-12, 03:09 PM
  3. VERTICAL BRACE WORKPOINTS
    By gregr.190618 in forum Revit Structure - General
    Last Post: 2008-09-18, 03:58 PM
  4. AutoCAD 2008 Visual Styles - Show circular structure as circular not multi sided
    By robert.scragg in forum AutoCAD 3D (2007 and above)
    Last Post: 2008-07-14, 02:38 PM
  5. Replies: 1
    Last Post: 2007-08-04, 08:05 PM
