Results 1 to 1 of 1
Thread: CP218-4: Automate Workflows Using AutoCAD Map 3D 2010 Workflow Framework
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default CP218-4: Automate Workflows Using AutoCAD Map 3D 2010 Workflow Framework
    Instructor: Sharanabasappa Revadigar
    Class Description: For the first time ever, AutoCAD Map 3D provides a visual designer canvas for authoring powerful workflows and chaining together all the involved activities entirely visually! Imagine building a workflow that loads some GIS layers, zooms/pans to a specific area of interest, and then allows creation of a new AutoCAD entity that you can then turn into a geospatial feature in less than two minutes! The workflow framework harnesses the power of the new Windows Workflow Foundation introduced since .NET 3.0 and exposes its full capabilities declaratively right at your fingertips. Imagine building workflows using domain-specific tools that afford plug-and-play. The framework is fully configurable and extensible. It comes with an API that boosts instant ROI for building a wide variety of functionality within a short time span and helps automate many of the mundane steps involved. The framework is complementary to action recorder, LISP, and other tools, but provides more power with control flow and decision points in the workflow. You will learn how to author, edit, test, run, and share workflows with other end users. The workflow framework affords data agnostic behaviors that help in reuse of workflow over disparate data sets.
  1. CP330-2: Build Powerful Workflows Using the AutoCAD® Map 3D 2011 Workflow Framework API
    Last Post: 2015-08-07, 05:19 PM
  2. CP218-3: AutoCAD APIs: The Right Tools for the Job
    Last Post: 2014-12-01, 01:48 AM
  3. CP304-3L: Build Powerful Workflows Using AutoCAD Map 3D 2010 Workflow Framework API
    Last Post: 2014-12-01, 01:38 AM
  4. Replies: 5
    Last Post: 2010-05-24, 01:17 PM
  5. Replies: 0
    Last Post: 2010-03-23, 03:16 PM
