Results 1 to 1 of 1
Thread: MA218-2L: Mechanical Simulation With Autodesk Inventor Professional
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default MA218-2L: Mechanical Simulation With Autodesk Inventor Professional
    Instructors: Shakeel Mirza with Ravi Akella, Peter Maxfield, J.D. Mather
    Class Description: This hands-on lab is designed to show users the typical workflow of an industrial simulation. Starting from the description of the real problem, the exercise takes the user through different steps of definition of the simulation model, selecting the right supports and loads corresponding to the real situation, meshing, running the analysis, interpreting the results, and finally evaluating their accuracy. The user is then taken through refining the mesh to get a higher level of confidence in the results by obtaining an optimal mesh.
  1. Replies: 0
    Last Post: 2015-08-07, 05:34 PM
  2. MA204-4: Autodesk Inventor Simulation Sneak Peek
    By Autodesk University in forum Manufacturing
    Last Post: 2014-12-01, 03:26 AM
