Results 1 to 1 of 1
Thread: MA318-3L: I've Been Framed! Using the Autodesk Inventor Frame Generator and Weldments
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default MA318-3L: I've Been Framed! Using the Autodesk Inventor Frame Generator and Weldments
    Instructors: Rollin Godette with Stan Wile, Jim Swain
    Class Description: This class is designed to instruct attendees in the use of the Frame Generator and Weldment environment in Autodesk Inventor. Attendees will use the Frame Generator to create frames from 3D sketches and solids. The created frame will then be converted to weldments to add preparations, weld features, and post-weld machining features. Finally attendees will document and annotate their design using the appropriate tools in the Drawing Manager.
  1. MA318-1V: Stick It Together with Autodesk® Inventor® Weldments
    By Autodesk University in forum Manufacturing
    Last Post: 2015-08-07, 05:33 PM
  2. MA318-2: Putting a Little Style Into Your Autodesk Inventor Designs
    Last Post: 2014-12-01, 03:57 AM
  3. Replies: 0
    Last Post: 2014-12-01, 03:39 AM
  4. Replies: 0
    Last Post: 2013-04-17, 04:52 AM
  5. Inventor Frame Generator New Profile Creation
    By allan.edlington.199728 in forum ATP Course Wishlist
    Last Post: 2009-05-07, 03:00 PM
