Results 1 to 1 of 1
Thread: SE222-2: Reading Between the Reference Lines
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default SE222-2: Reading Between the Reference Lines
    Instructor: Brian Mackey
    Class Description: Do you need a warping double “T” or a battered pile? How about a door with a swing angle? "How are these objects created?" you ask. The simple answer is reference lines. This session will discuss the differences between reference planes and reference lines. We will cover how to use reference lines to control angles of elements and how to properly constrain them. NOTE: This session will demonstrate structural components only.
  1. SE222-1: Not All Trusses Require the Autodesk Revit Structure Truss Tool
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:42 AM
  2. Difference between Reference lines and Reference planes
    By adnama in forum Revit Architecture - General
    Last Post: 2009-10-28, 04:39 PM
  3. Symbolic lines sweep along reference lines
    By dduarte in forum Revit Architecture - General
    Last Post: 2006-04-21, 01:44 AM
  4. Reference lines?
    By aliya14 in forum Revit Architecture - Families
    Last Post: 2005-01-14, 05:36 AM
  5. Reference Lines
    By GuyR in forum Revit Architecture - Families
    Last Post: 2004-10-26, 10:18 PM
