Results 1 to 1 of 1
Thread: SE314-1: Using Shared Parameters in Autodesk Revit Structure
    2012-11
    3,030
    Default SE314-1: Using Shared Parameters in Autodesk Revit Structure
    Instructor: Nick Hugley
    Class Description: You’ve used out-of-the-box families in your project and created schedules using them, but you need more information for a more detailed schedule. You’ve read or heard that if you use shared parameters, you can schedule them and add more information into your model. So what are these shared parameters and are they different from other parameters? I will show you how to create shared parameters and add these to out-of-the-box families and new families. You’ll be able to add footing bar sizes and quantities to a family and they will show up in a schedule. A wood shear wall placed in the model can have a schedule with the stud and sheathing size along with fasteners and hold down types. Use live schedules instead of static schedules.
  1. SE314-2: Streamlined Structural Analysis Using Autodesk Revit Structure and RISA
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:40 AM
  2. 2014: favorite shared parameters in Revit MEP
    By mehdi.kardehi565550 in forum Revit MEP - General
    Last Post: 2014-03-04, 07:23 PM
  3. SE314-1: The Consulting Engineer's Guide to Implementing Revit Structure
    By Autodesk University in forum Structural Engineering and Design
    Last Post: 2013-05-05, 02:26 AM
  4. Shared Parameters - Revit Upgrade
    By Illiniwek in forum Revit MEP - General
    Last Post: 2012-04-25, 02:15 PM
  5. Autodesk Shared Parameters File
    By zbrown in forum Revit MEP - General
    Last Post: 2010-07-13, 05:18 PM
