Results 1 to 1 of 1
Thread: SE304-3L: Yes! You Can Document Your Autodesk Revit Structure Model
    Autodesk, Inc. Autodesk University's Avatar
    2012-11
    3,030
    Default SE304-3L: Yes! You Can Document Your Autodesk Revit Structure Model
    Instructors: Jonathan Brazier with Tony DiMartino, David Harrington, Mathew Miller
    Class Description: Did you ever think you could create construction documents in Revit that rival or exceed your AutoCAD® drawings? Revit Structure is a powerful physical and analytical modeling tool, but it is also excellent design documentation software. In this session you will use Revit Structure’s tools and components to efficiently create clear, accurate “live” sections, details, 3D views, and schedules. You will also create Typical Details in Revit using those AutoCAD details that we all have in our libraries.
  1. SE304-2: Using Autodesk Revit Structure to Reduce Labor and Maximize Benefits
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:49 AM
  2. SE114-2: Utilizing Autodesk Revit Structure to Model and Document Concrete Reinforcing
    Last Post: 2014-12-01, 03:41 AM
  3. Replies: 1
    Last Post: 2013-07-03, 06:19 AM
  4. SE304-2: Creating Trusses with Revit Structure
    By Autodesk University in forum Structural Engineering and Design
    Last Post: 2013-05-05, 02:25 AM
  5. SE114-1: Using Revit® Structure to Document the Structural Model
    Last Post: 2013-05-05, 02:20 AM
