Results 1 to 1 of 1
Thread: SE304-2: Using Autodesk Revit Structure to Reduce Labor and Maximize Benefits
    2012-11
    3,030
    Default SE304-2: Using Autodesk Revit Structure to Reduce Labor and Maximize Benefits
    Instructor: Joy Beers
    Class Description: Revit Structure can be used to reduce the effort of the design and documentation process. Once the art of modeling is mastered, you can take advantage of the “information” aspect of BIM. A model, when coordinated with linked models,  updated with Revit links to structural design software, and  embellished with families, can become “model perfect”. The benefits of the process come in the creation of schedules for LEED® certification material take off, the verification of cost estimates, and the reduction of drafting time.
  1. SE304-1: Integrated Modeling for Successful Project Delivery Using Autodesk Revit
    By Autodesk University in forum Structural Design and Engineering
    Last Post: 2014-12-01, 03:52 AM
  2. SE104-1: Maximize the Use of Autodesk Revit Structure Extensions
    Last Post: 2014-12-01, 03:49 AM
  3. SE304-3L: Yes! You Can Document Your Autodesk Revit Structure Model
    Last Post: 2014-12-01, 03:47 AM
  4. Replies: 1
    Last Post: 2013-07-03, 06:19 AM
  5. SE304-2: Creating Trusses with Revit Structure
    By Autodesk University in forum Structural Engineering and Design
    Last Post: 2013-05-05, 02:25 AM
