Thread: Renumber Tag segment
    2009-11
    Raleigh, NC
    700
    Default Renumber Tag segment
    How do I toggle the tag to renumber instead of create new?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,468
    Default Re: Renumber Tag segment
    Huh?
    Are you wanting to renumber existing parcels? If you have your menubar visibile, the Parcels menu allows you to run the AeccEditParcelNumbers command (or you could type that command) which will allow you to renumber parcels.
    If your contextual ribbon panels are enabled, the ribbon may show an option to renumber parcels once you have an existing parcel selected. I'm not certain on this one as my current drawing does not have any parcels to test.
    2009-11
    5,536
    Wonder if the OP is getting a 'not in tag mode' error when attempting to renumber?
    If that is the case, simply edit the label style, general tab, from label to tag.
    Cheers
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
  1. renumber points
    By jenniferchavez in forum AutoCAD Civil 3D - Survey
    Last Post: 2012-10-09, 08:28 PM
  2. Renumber ballons
    Last Post: 2011-10-18, 08:59 AM
  3. Renumber Views
    By antman in forum Revit Architecture - General
    Last Post: 2011-02-25, 06:02 PM
  4. Renumber Tag IDs
    By kristina.bollin596153 in forum NavisWorks - General
    Last Post: 2010-08-24, 10:51 AM
  5. VBA Sheet Set Renumber
    By SRBalliet in forum VBA/COM Interop
    Last Post: 2005-11-14, 07:49 PM
