Thread: Cannot repeat adaptive component
    2012-09
    12
    Default Cannot repeat adaptive component
    Hey,
    I am having trouble repeating this component, I think it has to do with the divided surfaces being drawn on different work planes.
    Is there another way to draw this? I have tried many times now, with no success. What is important is that the whole form is within 1200mm x 2200mm x 3300mm.
    Thank you.
    2015-12
    Orlando, FL
    1,049
    Default Re: Cannot repeat adaptive component
    I don´t have Revit 2015 to open your file, but... my comment is that it is not clear in your question whether that object is the repeater that you want to apply to a surface, or the surface onto you want to apply a repeater (in that case, what is the repeater)?
  1. Replies: 0
    Last Post: 2015-08-07, 02:11 PM
  2. 2015: BIM object in adaptive component?
    By kerber.g685733 in forum Revit Architecture - General
    Last Post: 2014-12-17, 09:54 PM
  3. Adaptive Component Tree Column.
    By craighowie in forum Revit - Conceptual Design Tools
    Last Post: 2010-10-18, 02:09 AM
  4. UV grid by intersection + Adaptive component
    By pfaudler in forum Revit - Conceptual Design Tools
    Last Post: 2010-10-12, 01:40 PM
  5. Adaptive Component VS Mass
    By craighowie in forum Revit Architecture - General
    Last Post: 2010-07-14, 08:18 PM
