Thread: Hydronic supply and Return Piping Visibility Issue
    2015-10
    Question Hydronic supply and Return Piping Visibility Issue
    Hello. I am attempting to model some hydronic supply and return piping in the generic, out of the box "1 - Plumbing" plan view and it is not visible. My view range is correct (double checked that one first). I have tried (in vain) to locate where to control their visibility. I have not monkeyed with things; no view template is applied, discipline and sub-discipline remain set to "plumbing"...
    What gives, man!!
    Any advice would be greatly appreciated.
    Thanks!
    2011-01
    226
    Default Re: Hydronic supply and Return Piping Visibility Issue
    This is a tough one to diagnose since there are so many things that could be turned off - all easily verified though.
    1. Is the pipe category turned on?
    2. When modeling the pipe is the associated level and elevation within the view range?
    3. Are worksets being used? If so is the active workset set to visible in the view where you are modeling?
    4. You said it is a "plumbing" view, and you are modelling a hydronic system. Is there a filter in your visibility graphics that is turning off hydronic piping? (Generally hydronic piping would be used for mechanical systems, not plumbing.)
    Those are the main things that come to mind. Hope it helps!
    2014-02
    44
    I would put money on a veiw filter.
    Undervisablity graphics, filter tab there is probably a hydronics filter to turn of hydronics.
    When you start a new mechinal templete project it defualts that way for some reason... very annoying.
  1. Replies: 10
    Last Post: 2016-06-27, 12:04 AM
  2. Hydronic piping?
    By RCA4697 in forum Revit MEP - General
    Last Post: 2010-07-13, 03:58 PM
  3. Return Air System Prints Laighter than Supply
    By gvluisi in forum Revit MEP - General
    Last Post: 2010-06-29, 12:40 PM
  4. Supply Air - Return Air Rendering
    By mjward1 in forum Revit - Rendering
    Last Post: 2008-11-12, 03:46 PM
  5. Hydronic Return/Supply chiller
    By alan.jackson in forum Revit MEP - General
    Last Post: 2007-08-10, 03:46 PM
