Results 1 to 6 of 6
Thread: Arabic Font - Text Inconsistencies when exporting from Revit to AutoCAD
    Default Arabic Font - Text Inconsistencies when exporting from Revit to AutoCAD
    Hi All,
    Were having some issues in our office when exporting Arabic Text/Font from Revit to AutoCAD.
    The Arabic font appears fine in our Signage Schedules within Revit however when exporting the Schedules to AutoCAD (deliverable to client) the Arabic Font/Text changes completely and goes from a single line text to a double line text. Please refer to the two attached snapshots to show the issue. The Image called Arabic Text in Revit is the correct Text/Font, and then the second image called arabic Text in AutoCAD from Revit is incorrect.
    PLEASE NOTE that we have pre-installed Arabic Font .shx TrueType Files which are exactly the same in both AutoCAD and Revit.
    Would anyone have a work around for this problem.
    Regards
    Etienne Mouton
    2003-03
    Philadelphia, PA
    2,390
    Default Re: Arabic Font - Text Inconsistencies when exporting from Revit to AutoCAD
    Revit and AutoCAD treat fonts differently, which can result in changes to the text and its formatting when exporting from Revit to AutoCAD. I am not aware of a means to work around this, other than to tweak the text in AutoCAD. You may be able to adjust the text height in AutoCAD to get the text to more closely match the original layout in Revit.
    Thanks David,
    Its a little frustrating as there is no work around! Were just afraid itll go unnoticed and our entire signage package would be a mess
    Regards
    0,0,0 The Origin
    8,570
    May be heplful, may not -
    can you get the text correct in Word?
    I imported the text from Word into AutoCAD mtext a few years ago when working with chinese text labels.
    2013-09
    26
    Have you tried to import the correct text from autocad into revit and using that? or just to see how it responds?
    I have only had to deal with getting revit text to mad autocad...it will never be perfect for various reasons (shape files,ctb files vs revit line weights etc.) but i have been able to get it really damn close
    if you try it in the opposite order maybe it will help revit export correctly?
    definitely not the best practice as you will have to break many auotcad importing rules of thumb but it may be worth a try as it may reveal some of the issues and differences that you see in the properties/type properties of the text
    *this thread may also be better off in a revit specific section as I'm not sure how many revit guys will see this
    I have really only dealt with this stuff in title blocks which is even more frustrating because autocad title blocks are often using ctb files to make certain text appear bold...revit only allows one bold setting then you have to crank up the actual line weight which does not have the same effect...very tough to explain to people when you cannot achieve the EXACT same style
    2023-01
    Did anyone ever find a solution to this problem or we'll just never talk about this?
  1. Support for bidirectional text, such as Arabic and Hebrew during printing
    Last Post: 2014-10-25, 09:32 AM
  2. Arabic font problem
    By stal in forum AutoCAD General
    Last Post: 2013-04-07, 05:33 AM
  3. AutoCAD needs a strikethru text font for doing record drawings
    Last Post: 2012-07-18, 03:46 AM
  4. Text font shows wrong font - revit to blame?
    By jblack.150078 in forum AutoCAD General
    Last Post: 2007-10-10, 08:11 PM
  5. AutoCAD 2007 - Dimension font changes when editing text
    By BushDog1 in forum AutoCAD General
    Last Post: 2006-05-27, 02:48 AM
Tags for this Thread
