Thread: Automatic Renumbering Shared Parameters
    2006-10
    Durango, Mexico
    127
    Default Automatic Renumbering Shared Parameters
    Hi everyone
    So I have a lot of elements (Supports) that have a custom parameter but I need to renumber them all again, is there an add in that anyone of you would recommend? the ones that I have found change the "Mark" Valure but don't work for other parameters.
    Thanks in Advance
    Alex
    2002-09
    Madison, WI
    5,682
    Default Re: Automatic Renumbering Shared Parameters
    There's a rather slick tool from CTC called Spreadsheet link. You can select any family, category, whatever and any parameters associated with those objects.
    Export to excel or you can do it right in the program and renumber from 1 to 1000 or what ever in about 2 sec. Only hitch is that no-one else can really be in the model or you'll get some errors depending on number of objects you're trying to change.
    Dave Peterson
    BIM Coordinator
    Acad - 2019 - Revit 2021 w/ BIM 360 - Navisworks - Ensacpe - Lumion - Windows 10 OS - i7-10850H 2.7GHz 64GB Ram - Nvidia Quadro RTX 3000
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
    2006-10
    Durango, Mexico
    127
    Thanks David
    im going to do a search about this add in
  1. 2014: Criteria for Project Parameters vs. Shared Parameters
    By jagostinho in forum Revit - Platform
    Last Post: 2014-03-21, 02:46 PM
  2. Automatic Update of Attributes and Fields when DB Parameters Change
    Last Post: 2008-02-28, 08:24 PM
  3. Shared Parameters
    By justin.taylor in forum Revit Architecture - Tips & Tricks
    Last Post: 2007-07-10, 01:24 PM
  4. SHARED PARAMETERS
    By lila in forum Revit Architecture - General
    Last Post: 2007-03-01, 01:06 AM
