Thread: Text hard to read on 11x17
    2008-06
    Default Text hard to read on 11x17
    Text in an instrument bubble (ie. Control Valve) is framed making it hard to read on a plot 11x17. I can not find a way to remove the frame, the only work arround I have used is reduce the lineweight. I have mostly just used the original non-P&ID instrument bubble already on the document.
    in the upper right corner
    3,504
    Default Re: Text hard to read on 11x17
    Contrats on your first post.
    Sorry, I don't know anything about AutoCAD P&ID, but do you know if that instrument bubble is a block?
    Can it be redefined?
    Either redefine it without the frame or put the frame on a separate layer that can be frozen?
    How is the the instrument bubble placed in the drawing, like is there a tool bar that places it there?
    By your original post, I assume the frame is the problem so if removed your text will be more readable?
    2008-06
    Thanks Ted, it's been a long time sense I've been on AUGI. Found I could use "frame" set to zero to just turn them off for plotting.
  1. open and read text file
    By bandent in forum AutoLISP
    Last Post: 2010-04-15, 08:46 PM
  2. Read / Write To Text File
    By caddog71 in forum VBA/COM Interop
    Last Post: 2008-05-27, 06:40 PM
  3. Replies: 4
    Last Post: 2007-05-24, 03:24 PM
  4. The text in the Mtext editor is faint and very hard to read.
    By Glenn Pope in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-16, 04:45 PM
  5. Hard return in Mtext when inserting text
    By gstankus in forum AutoCAD General
    Last Post: 2004-06-17, 07:06 PM
