Results 1 to 10 of 17
Thread: Lisp routine doesn't work
    2012-02
    82
    Default Lisp routine doesn't work
    I am trying to delete a variety of blocks from a large number of drawings. The DELBLK lisp routine is the only one I have found. The problem is that the DELBLK routine doesn't work. I get an error message or "0 blocks deleted".
    Does anyone have any experience with this lisp routine or have another which does work?
    Thank you
    Past Vice President / AUGI Volunteer peter's Avatar
    2000-09
    Honolulu HI
    1,109
    Default Re: Lisp routine doesn't work
    I just threw this one together.
    It will delete all blocks in a drawing (including inside other blocks) and purge the drawing of the block definition.
    P=
    ... I made a couple modifications and uploaded the revised file ...
    ;___________________________________________________________________________________________________________
    ; Function for deleting blocks from a drawing.
    ; Syntax: (blockdelete "detailbub*")
    ; Written By: Peter Jamtgaard 2014 copyright 2014 all rights reserved
    (defun C:BlockDelete ()
     (blockdelete (getstring "\nEnter Block Name: "))
    (defun BlockDelete (strWCBlockName / objBlock lstBlockDefinitions lstBlockInstances)
     (command "layer" "u" "*" "")
     (setq strWCBlockName (strcase strWCBlockName))
     (vlax-for objBlock (vla-get-blocks
                         (vla-get-activedocument
                          (vlax-get-acad-object)))
      (if (wcmatch (strcase (vla-get-name objBlock)) strWCBlockName)
       (setq lstBlockDefinitions (cons objBlock lstBlockDefintions))
       (vlax-for objItem objBlock
        (and
         (wcmatch (vla-get-objectname objItem) "AcDbBlockReference,AcdbMInsertBlock")
         (wcmatch (strcase (vla-get-name objItem)) strWCBlockName)
         (setq lstBlockInstances (cons objItem lstBlockInstances))
     (apply 'and
      lstBlockObjects
      (apply 'and (mapcar 'ObjectDelete lstBlockInstances))
      (regen)
      lstBlockDefinitions
      (apply 'and (mapcar 'ObjectDelete lstBlockDefinitions))
    (defun ObjectDelete (objItem)
     (errortrap (quote (vla-delete objItem)))
    (defun Regen ()
     (errortrap (quote (vla-regen (vla-get-activedocument (vlax-get-acad-object)) 0)))
    ; Standardized Error Trap
    (defun ErrorTrap (symFunction / objError result)
     (if (vl-catch-all-error-p
          (setq objError (vl-catch-all-apply
                         '(lambda (X123)(set X123 (eval symFunction)))
                          (list 'result))))
      nil
      (if result result 'T)
    (vl-load-com)
    AutomateCAD
    2012-02
    82
    As they say out on the east coast "beauty, eh". Thanks for the help
    2005-06
    in the upper right corner
    3,508
    Quote Originally Posted by boyerd492098 View Post
    I thought that was a Canadian thing?
    #Bob&DougMckenzie
    2012-02
    82
    It most certainly is! Nothing like partying with a 2-4 of beer!
    Peter,
    Do you mind if I pass your lisp routine on to others?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Instead of passing it on to others, why not pass them a link to the code?
    2001-03
    Tallahassee, FL USA
    3,667
    2
    +1 Save the complete file and add the link http://forums.augi.com/showthread.ph...doesn-t-work#2 to the comments section.
    That way if you have a problem with the code or would like an added feature later on you know where to ask for it. Knowing where to get code would be more useful to them than just one routine.
    Passing a link is easier than passing a file anyway.
    2012-02
    82
    Good morning Peter,
    I have set up blocks for the Engineers Seal, the companys Permit to Practice and an Issued for Construction stamp. I named them ifc_stamp, permit_stamp, rbh_stamp, jk_stamp. You will notice that they have "_stamp" in common. I tried using a wild card "*_stamp" and it does remove all the visible blocks in the file. But if I open the Insert Block dialogue box I see that not all the blocks have been deleted/purged from the file. Is there some way to enhance your lisp routine to pressure wash all references from the file?
    Thank you
    2000-09
    Honolulu HI
    1,109
    I revised the program once, did you try the second version?
    Try the one posted above and see if it does it better.
    That is why I revised it. I noticed that the part where it purges the block definition only deleted one of the definitions.
    The new version should delete all of them
    P=
    AutomateCAD
    2012-02
    82
    Posted above? Where above? I dun't see it.
    Don
  1. Getting my lisp routine to work in C3D 2015
    By dmackey.143011 in forum AutoLISP
    Last Post: 2015-04-06, 07:22 AM
  2. why doesn't this lisp work in a macro?
    By chuh in forum AutoLISP
    Last Post: 2014-09-09, 05:56 PM
  3. LISP to Explode Dynamic Blocks Doesn't Work
    By stusic in forum AutoLISP
    Last Post: 2013-06-26, 05:20 PM
  4. Copy LISP doesn't work when zoomed out!
    By brekkja in forum AutoLISP
    Last Post: 2013-04-02, 11:23 AM
  5. lisp worked in 07 doesn't work in 09?
    By Hammer.John.J in forum AutoLISP
    Last Post: 2009-08-07, 04:22 PM
