Thread: Plan Symbol Offsets are Offsetting in the Opposite Direction as intended
    2014-05
    13
    Default Plan Symbol Offsets are Offsetting in the Opposite Direction as intended
    Hello,
    Im hoping that this is a simple fix, i created plan symbol offsets using parameters. They work correctly except that the offset is going in the opposite direction i want them to. Offsetting wont work with negative number values so im not sure the easiest way to fix this issue. Any help would be great. Thanks!!
    All AUGI, all the time CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    813
    Default Re: Plan Symbol Offsets are Offsetting in the Opposite Direction as intended
    Sorry, I'm not certain about what you're describing. Can you post some images? Or perhaps the Revit file?
  1. 2013: Fittings Bend Wrong Direction, and Weird Offsets
    By tbonebanjo229101 in forum Revit MEP - General
    Last Post: 2015-01-09, 12:30 AM
  2. Plan Detail Opposite
    By captainbunsaver in forum Revit Architecture - General
    Last Post: 2008-03-25, 02:20 PM
  3. Controlling Direction of Offsets
    By raymeek in forum VBA/COM Interop
    Last Post: 2008-03-17, 01:03 PM
  4. Plan Region Bug or Intended?
    By Steve Jager in forum Revit Architecture - General
    Last Post: 2006-11-30, 06:45 PM
  5. Replies: 6
    Last Post: 2006-10-11, 01:21 PM
