Thread: Adding the same contour polyline to a surface multiple times
    2013-11
    36
    Default Adding the same contour polyline to a surface multiple times
    Is there any detrimental effect to adding the same polyline contours to a surface multiple times?
    I'm sure the question would arise as to why a person would want to do that... Here's an example - I have a surface that was initially made from polylines. Then it was added to over here. Then tweaked over there, etc.
    Now, it's difficult to determine which are the "new" polyline contours and which ones are already included in the surface without an extensive comparison. So the question is, is there any harm in adding -all- the polylines to the surface again?
    Thanks.
    Cairo - no, not Illinois
    5,069
    Default Re: Adding the same contour polyline to a surface multiple times
    uhm.... i would expect a drastic slowdown in performance, and a greatly increased rick of error, crashes, and hangs while c3d tried to calculate using a a lot of redundant duplicated data.
    2013-11
    36
    Bingo... That's exactly what I'm experiencing. To carry the thought further, it was suggested I simply remove all additions of contour polys from the definition and add them fresh, so to speak. My thinking is that approach would trash any and all edits. This is an older job and nobody wants to reinvent the wheel on it...
    So the bottom line is multiple adds is no bueno.
    2006-10
    Durango, Mexico
    127
    Have you tried locking the surface>, isolating all polylines>, deleting them all>, extract polylines from surface.
    It may work and would clean up alot of unused polylines.
    Regards
    Alex
  1. Polyline contour labeling in Civil 3D
    By jwissler in forum AutoLISP
    Last Post: 2009-02-26, 10:00 AM
  2. Quick adding of multiple closed polyline areas
    By CBLENDERMANN in forum AutoLISP
    Last Post: 2008-05-29, 04:21 PM
  3. Audit is slow when run multiple times
    By charles.stewart in forum AutoCAD General
    Last Post: 2007-06-11, 06:37 PM
