Results 1 to 7 of 7
Thread: Alignment Direction
    2009-11
    Raleigh, NC
    780
    Default Alignment Direction
    When creating alignments at the "Press to accept alignment direction or [Reverse]:" prompt, my direction arrow is not showing up. Yes I am sure. at first I thought size of alignment may be causing arrow to be very small. I have tried creating multiple alignments and its not working.
    I have recently upgraded from Civ3D 2014 to 2015 and I have noticed several glitchy issues.
    2009-11
    Raleigh, NC
    780
    Default Re: Alignment Direction
    Just discovered it won't when UCS is not world.
    Cairo - no, not Illinois
    4,988
    When I create an alignment from object, I'm invariably in the WCS -- yet sometimes the direction arrow will not appear. I've tended to blame the craptastic corporate graphics card.... As a result I've more than once had to recreate the alignment to get it in the right direction
    2015-12
    Austin, TX
    6
    Why recreate the alignment? There's an option to reverse it in the ribbon.
    1. Select the alignment and look for the Alignment contextual ribbon tab. AlignmentContextualRibbonTab.png
    2. Locate the Modify panel and click on the word Modify to expand the flyout panel. AlignmentModifyPanel.png
    3. In the expanded flyout Modify panel, click on Reverse Direction. AlignmentReverseDirection.png
    More info on the Autodesk Knowledge Network here:
    https://knowledge.autodesk.com/suppo...0EAEC-htm.html
    --Tom
    2009-11
    5,656
    Quote Originally Posted by C3D.TomR View Post
    1+
    Not sure why they nested it, but this is what I do as well.
    Cheers
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    4,988
    Quote Originally Posted by C3D_TomR View Post
    --Tom
    You did not that was a year old post??
    simple enough to just hit U ....
    2009-11
    5,656
    I did not, as it happens. Haha
    - - - Updated - - -
    [Edit] - A belated 'thread officially zombified'
    Computer Specs:
  1. Alignment sheet generation direction
    By Lizar24 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2013-06-19, 05:40 PM
  2. 2012: How to create points on LHS alignment which are at even chainage w.r.t the main centreline alignment
    By gary.chan.kc355500 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2013-04-25, 07:25 PM
  3. Direction preview when creating alignment
    Last Post: 2012-06-12, 05:59 PM
  4. Alignment Station Direction
    By Ryan-13 in forum AutoCAD Civil 3D - Alignments
    Last Post: 2011-10-04, 09:03 AM
