Thread: Copy an paste Autocad drawing oBject by VBA
    2008-02
    40
    Default Copy an paste Autocad drawing oBject by VBA
    Hi to everybody,
    I'm searching for some sample code in order to copy all drawing objects into clipboard and paste into another drawing.
    Seem it's mission impossible with VBA embedded in Autocad.
    Thank you,
    5,525
    Default Re: Copy an paste Autocad drawing oBject by VBA
    Can you not instead simply use the COPYBASE Command OOTB?
    2008-02
    40
    Thank you for your answer, I have to replace some parts in 130 DWG !! so I'm searching something like a procedure, your command work fine, I'll try to use in a script....
    Thank you.
    2012-11
    Italy
    65
    if sticking to VBA you could use the "CopyObjects" method of the Document or Database object
    the following code copies all object from the active document to a newly created one but you can simply adapt it to your needs
    Option Explicit
    Sub CopyAllObjects()
    Dim sourceDwg As AcadDocument, destDwg As AcadDocument
    Set sourceDwg = ActiveDocument
    Set destDwg = Documents.Add
    sourceDwg.CopyObjects allObjectsArray(selectAllObjects(sourceDwg)), destDwg.ModelSpace
    End Sub
    and here they are the called functions
    Function selectAllObjects(myDoc As AcadDocument) As AcadSelectionSet
    Set selectAllObjects = CreateSelectionSet("mySel", myDoc)
    myDoc.Application.ZoomAll
    selectAllObjects.Select acSelectionSetAll
    End Function
    Function allObjectsArray(ss As AcadSelectionSet)
    Dim iEnt As Long
    ReDim Objects(0 To ss.Count - 1) As AcadEntity
    For iEnt = 0 To ss.Count - 1
        Set Objects(iEnt) = ss.Item(iEnt)
    Next iEnt
    allObjectsArray = Objects
    End Function
    Function CreateSelectionSet(SSset As String, Optional myDoc As Variant) As AcadSelectionSet
    If IsMissing(myDoc) Then Set myDoc = ThisDrawing
    On Error Resume Next
    Set CreateSelectionSet = myDoc.SelectionSets(SSset)
    If Err Then
        Set CreateSelectionSet = myDoc.SelectionSets.Add(SSset)
    Else
        CreateSelectionSet.Clear
    End If
    End Function
    2008-02
    40
    Thank you RICVBA I'll try asap
    2019-05
    15
    grobnik, still no luck?
  1. 2013: AutoCAD Drawing Size - copy/paste
    By walt.sparling in forum AutoCAD General
    Last Post: 2014-03-08, 07:05 PM
  2. Replies: 4
    Last Post: 2013-11-17, 09:49 PM
  3. Copy / Paste object coordinates into text
    By IanR in forum AutoCAD Wish List
    Last Post: 2006-11-06, 09:32 PM
  4. Copy/Paste From Autocad
    By IanR in forum Inventor Wish List
    Last Post: 2006-08-07, 03:33 PM
  5. Copy/Paste Object Data
    By gis.68227 in forum AutoCAD Map 3D - Wish List
    Last Post: 2005-02-01, 03:21 PM
