Thread: Circuiting to Multiple Connectors
    Wish List Administration
    2011-08
    4,581
    Default Circuiting to Multiple Connectors
    Summary: Right now Revit only recognizes the first connector that gets circuited and will only place that circuit in the tag for a device.
    Description: Right now Revit only recognizes the first connector that gets circuited and will only place that circuit in the tag for a device. There are many times when a light fixture needs to be circuited to two different circuits. It would be nice if we didn't have to tag the wires to show the circuiting. I would much prefer it if we could just tag the light fixture and have all of the circuits populate instead of just the first one.
    Product and Feature: Revit MEP - MEP Electrical Circuits - (Electrical)
    Submitted By: Beth Hoerth on 02/09/2015
    2015-10
    Chicagoland
    73
    Default Re: Circuiting to Multiple Connectors
    I agree that electrical needs more core functionality for what we need everyday, and not workarounds. But here is a workaround:
    Use one of the Balanced Electrical Connector families that come with your installation. Nest 2 instances into a family (quad/light fixture). Add some parameters for controlling loads, voltage & # of poles (or family type - whichever best suits your workflow). When that's loaded, you can TAB+Select cycle to select that instance, then power & tag as you ordinarily would.
  1. Multiple Electrical Connectors
    By repp in forum Revit MEP - Families
    Last Post: 2012-11-09, 03:20 PM
  2. Multiple family connectors and systems
    By JJameson in forum Revit MEP - Families
    Last Post: 2012-10-10, 05:37 PM
  3. 2011: Terminal Box with Multiple Connectors
    By magicjsh853179 in forum Revit MEP - Families
    Last Post: 2011-07-14, 12:16 AM
  4. Multiple Connectors
    By awascher in forum Revit MEP - Families
    Last Post: 2009-06-23, 07:03 PM
  5. Multiple Connectors on Single Face?
    By nate.schlotz in forum Revit MEP - Families
    Last Post: 2008-08-07, 03:39 PM
