Thread: Part Builder - Safety End Treatment
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Part Builder - Safety End Treatment
    Here is a Part Builder structure based on a Louisiana DOTD Safety End Treatment. I'm not sure it is perfect, but it does what I want it to do.
    How you can add it to your catalog
    I would recommend creating a new chapter in your Part Builder for this new part. Creating a new chapter will create a sub folder within the Pipes Catalog folder. The folder location can be assigned through the SetNetworkCatalog command.
    Once all of that is complete, I believe you can extract all of the files in the attached zip file into this new chapter's sub-folder. You would then need to Regenerate the Catalog to have this new part recognized.
    If you have any questions, I'll try to answer them. Be aware, it has been more than two months since I created this and I may have forgotten some steps.
    9,805
    Question Re: Part Builder - Safety End Treatment
    Is that to say that we should manually create a new folder here (for a 2015 install)
    -----> C:\ProgramData\Autodesk\C3D 2015\enu\Pipes Catalog\US Imperial Structures
    so that the extracted files would live in "C:\ProgramData\Autodesk\C3D 2015\enu\Pipes Catalog\US Imperial Structures\Other" (Where Other is the new "chapter")??
    Thanks.
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Part Builder - Safety End Treatment
    In a roundabout way, yes.
    When creating the chapter (named "Other" as you desire), the sub-folder "Other" would be created by the Part Builder interface. You would then extract the contents of the above attachment directly into that folder. It should not be located in a sub-folder of "Other".
    Once the data is in that folder, you would need to use the Part Builder interface to regenerate the catalog.
    I have changed the location of my parts catalog to point to the network.
    5,719
    FWIW -
    You might find the FDOT Civil 3D State Kit to be of use; they include their entire Design Standard via Parts Catalog, etc. among other criteria.
    I know you're in another state, so not directly applicable per-se.
    Cheers
  1. CV218-4: Get the Part: AutoCAD Civil 3D Part Builder
    By Autodesk University in forum Civil Infrastructure
    Last Post: 2014-12-01, 04:52 AM
  2. 2012: Part Builder
    By valejandro_ibarra in forum AutoCAD Civil 3D - Pipes
    Last Post: 2013-03-22, 08:24 PM
  3. Part Builder
    By a.navarrete in forum AutoCAD Civil 3D - General
    Last Post: 2009-04-16, 02:33 PM
  4. part builder
    By wag24 in forum AutoCAD Civil 3D - General
    Last Post: 2008-08-06, 10:14 PM
  5. Part Builder - Autolayout
    By sbrown.142299 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2008-06-30, 02:37 PM
