Thread: Default XREF Layer
    Wish List Administration
    2011-08
    4,581
    Default Default XREF Layer
    Summary: Be able to use a SETVAR to preset a Layer for XREFs
    Description: Be able to use a SETVAR to preset a Layer for XREFs (Like layer Xref).
    [] would use the current layer, but if a layer name was supplied, they would go to a default layer. you could still manually change them to any layer you wish, but it would help keep things organized - especially in a larger organization. If it was a SETVAR it could work in the Project Navigator, as well as vanilla AutoCAD.
    Product and Feature: AutoCAD Architecture - Project Navigator
    Submitted By: Mark Bauer on 02/16/2015
    2009-11
    5,585
    Default Re: Default XREF Layer
    Quote Originally Posted by Wish List System View Post
    Just use a Command reactor to store the current layer, set the desired layer current (i.e., "XREF"), and then restore original layer when done:
    (vl-load-com)
    (defun XrefReactorSample ()
      (or
        *XrefReactor*
        (setq *XrefReactor*
               (vlr-command-reactor
                 "My Xref Reactor"
                   (:vlr-commandcancelled . XrefCallback:CommandEnded)
                   (:vlr-commandended . XrefCallback:CommandEnded)
                   (:vlr-commandfailed . XrefCallback:CommandEnded)
                   (:vlr-commandwillstart . XrefCallback:CommandWillStart)
      (prompt "\nXREF reactor loaded. ")
      (princ)
    (defun XrefCallback:CommandEnded (rea cmd)
      (if (and (wcmatch (strcase (car cmd)) "*XATTACH,*XCLIP,*XREF")
               *XrefLayer*
        (setvar 'clayer *XrefLayer*)
    (defun XrefCallback:CommandWillStart (rea cmd)
      (if (wcmatch (strcase (car cmd)) "*XATTACH,*XCLIP,*XREF")
        (progn
          (setq *XrefLayer* (getvar 'clayer))
          (vla-add
            (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
            "XREF"
          ;;<-- set other layer properties here
          (setvar 'clayer "XREF")
    (defun c:StopXrefReactor ()
      (if *XrefReactor*
        (progn
          (vlr-remove *XrefReactor*)
          (setq *XrefReactor* nil)
      (prompt "\n** XREF reactor stopped ** ")
      (princ)
    (XrefReactorSample)
    (prompt "\nInvoke \"STOPXREFREACTOR\" command to stop. ")
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
  1. AEC - default style - default layer - strange lines
    By chopsuey in forum ACA General
    Last Post: 2011-08-20, 01:21 AM
  2. 3D Layer Setting Default to 2D Layer Settings
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-05-22, 10:01 PM
  3. Replies: 6
    Last Post: 2007-05-30, 05:45 PM
  4. Ability to Update an XREF Layer from the Layer Properties Manager
    Last Post: 2007-05-08, 12:50 PM
  5. Ignore XREF portion of layer name upon restoring layer state
    Last Post: 2006-11-08, 12:30 PM
