Thread: Rendering does not start, then rendering dialog disappears, then 3D view turns black
    2015-02
    Default Rendering does not start, then rendering dialog disappears, then 3D view turns black
    When I go to render a view, I click the "render" button on the rendering dialog, at which point the computer "thinks" for about 5 minutes, then the rendering dialog disappears and the 3D view I was trying to render goes black. This is only for certain views; other views render just fine. Anyone know what it could be?
    I do have another large Revit file linked to our model. I have made sure this linked model is not blocking any of our lights, and that all the lights are turned on, etc. Thanks!
    2005-04
    Saintlouis Missouri
    529
    Default Re: Rendering does not start, then rendering dialog disappears, then 3D view turns black
    I had this issue and it was a semi truck in the line of view close to where I set the render view from. This could also happen with the link. Take the link out of the view or even unload it for the render. Go to the plan and render view and see where it is set and if anything might be in its way. The other is you need the sun on. Sometimes you need to click the sun settings at the bottom of your screen. Hope this helps
    2008-09
    Nebraska & Iowa
    378
    Try re-creating the camera a few feet back from where you were and check the height settings on the camera.
  1. 2011: Rendering black masses!
    By damon.sidel in forum Revit Architecture - General
    Last Post: 2011-12-20, 05:43 PM
  2. Black and White Rendering
    By jspartz in forum Revit Architecture - Tips & Tricks
    Last Post: 2010-10-18, 11:44 AM
  3. Rendering Black Material
    By jodi_sherrell in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-12-29, 04:02 PM
  4. How to Make a Black and White rendering
    By yanyan77 in forum Revit - Rendering
    Last Post: 2009-10-20, 09:00 PM
  5. Water rendering black
    By TanelF in forum 3ds Max - mental ray
    Last Post: 2009-08-09, 12:48 PM
