Thread: Unable to create Central file
    AUGI Addict jsteinhauer's Avatar
    2015-11
    Madison, WI
    1,317
    Default Unable to create Central file
    Hello All,
    I am currently trying to setup a new project file in 2015 (SP5), and running head first into a huge road block. We recently updated our template which this project was started from. We also have recently signed up for A360. So starting from our new template, I created a project file, Updated the landing page, and started to add levels. I got to a point where I thought the team should now have access to this file, but I'm unable to select Activate Worksets. I'm not sure if this is an issue with 2015, our new template, or A360. I've restarted Revit, restarted my computer & Saved-As, and I get bupkis.
    Thank you in advance,
    Jeff S.
    'When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.' - R. Buckminster Fuller
    2015-11
    Madison, WI
    1,317
    Default Re: Unable to create Central file
    We diagnosed this to A360. For projects hosted upon our local server we must designate that we collaborate via LAN or WAN. Worksets are not available until after that selection is made (New workflow).
    Cheers,
    Jeff S.
  1. 2013: cannot create central file in revit server
    By markclarenzze in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-12-30, 09:09 PM
  2. 2014: Revit reporting Central File is not available, no one else is in file, can't save, won't create local file
    By patricks in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-10-03, 10:31 PM
  3. 2013: Unable to create local file on Revit Server 2013
    By dfi in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-09-03, 02:04 PM
  4. HEELP! unable to create AVI-file!
    By enidakratovic978386 in forum 3ds Max - General
    Last Post: 2011-03-11, 09:06 PM
  5. Can't create a new Central File
    By rtaube in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2010-09-30, 07:06 PM
