Thread: How To Recover AutoCAD DWG File ?
    Default How To Recover AutoCAD DWG File ?
    Tried to recover bak file, but there is no bak file in temporary files. AutoCAD didn’t recover the file itself. The version is 2014. There migt be some error occurred in saving process. Don’t know any solutions. Please help me to repair this file.
    Earth
    9,805
    Default Re: How To Recover AutoCAD DWG File ?
    By default, the .BAK file will be in the same location as the .DWG file.
    If there are any autosave files, they will be in your %temp% directory by default. If an autosave file is written at least twice, then there will be a .BAK file for the autosave file also in that same place.
    To find the locations for autosave and %temp%, go into OPTIONS, FILES tab, and refer to this:
    R.K. McSwain | CAD Panacea |
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    The command DRAWINGRECOVERY will bring up the Drawing Recovery Manager.
    In OPTIONS on the Open and Save tab make sure "Automatic save" and "Create backup copy with each save" are checked.
    I keep my "Minutes between saves" set to 10. With bigger drawings on less powerful PC's you would have to set it higher.
    2001-03
    Tallahassee, FL USA
    3,667
    There is also an Express Tool MOVEBAK that changes the destination directory for BAK files.
  1. Recover a drawing file when the Recover command fails
    By a_meteni in forum AutoCAD General
    Last Post: 2014-07-02, 03:34 PM
  2. Recover a file using the journal?
    By john.hainsworth in forum Revit Structure - General
    Last Post: 2008-05-15, 09:28 AM
  3. Recover a Drawing File
    By rhayes.99001 in forum ACA General
    Last Post: 2007-06-29, 06:38 PM
  4. Unable to recover a DWG file
    By martyk in forum AutoCAD General
    Last Post: 2006-12-05, 06:55 PM
  5. Cannot Recover drawing - AutoCAD 2005 file
    By CADKitty in forum AutoCAD General
    Last Post: 2006-10-03, 01:57 PM
