Part 1
I have a Solidworks assembly that is 7.5 MB in size. I IMPORT the Solidworks assembly file directing in to AutoCAD. The file comes in at 10MB as blocks. Some of the blocks are sub-assemblies from Solidworks, so I have blocks within blocks.
But as I work on the file in AutoCAD such as exploding the blocks down to their 3D solid form, the file size gets to be 15 MB. I have also tried NOT exploding the blocks and the file size is a little smaller. I can get the file size down to 13 MB with all the AutoCAD tricks. (Overkill, -purge, regapps, -wblock, overkill, audit, Brep)
Do you have any idea on how to get the file size of the IMPORTED Solidworks assembly files even smaller?
Part 2
When I look at the blocks in the imported file, I notice some blocks that should not be there. It seems that during the import of the Solidworks file, I am getting what I call “zero length blocks”. I other words, nothing is in the block when I insert it. It seems that Solidworks is importing block objects that have no geometry in them. Any ideas what is causing this?
jc
