Results 1 to 6 of 6
Thread: Field to display point coordinates relative to CURRENT ucs, not WORLD UCS
    I could stop if I wanted to jpcadconsulting347236's Avatar
    2011-09
    298
    Default Field to display point coordinates relative to CURRENT ucs, not WORLD UCS
    Hello gang,
    I've got a request to create a coordinates block that displays the X and Y distance from the origin point of the UCS that is current when the block is inserted.
    This seems to be eluding me, as all my attempts always display the X and Y distances to 0,0 in the World Coordinate System regardless of which UCS is current.
    Any help is, as always, much appreciated.
    -JP
    James Pertusi
    CAD Applications Consultant
    1 (646) 773 4834
    www.jpcadconsulting.com
    Cairo - no, not Illinois
    4,771
    Default Re: Field to display point coordinates relative to CURRENT ucs, not WORLD UCS
    If the block does not need to show dynamic coordinates, but just the coordinates it was originally inserted at, I'd look at a LISP routine to insert the block and stuff the attribute information into it.
    2001-03
    Tallahassee, FL
    3,272
    Something like:
    ;| Label for Point.
       PtLabel.lsp BY: TOM BEAUFORD
       ^P(or C:Label (load "PtLabel.lsp"));PtLabel
       BeaufordT@LeonCountyFL.gov
       Leon County Public Works/Engineering
    (defun C:PtLabel (/ ATTDIA)
          (setq ATTDIA (getvar "ATTDIA"))
          (setvar "ATTDIA" 0)
          (command "._INSERT"
                   "Pt_Coordinates"
                   (getpoint "Pick Point: ")						;Insert pt
                   (/ 0.1 (getvar "cannoscalevalue"))				;X Scale
    ;               (* (getvar "DIMTXT") (getvar "DIMSCALE"))	;X Scale (Alternate)
                   ""						;Y Scale
                   ""				                ;Rotation
                   ""					        ;Easting
                   ""					        ;Northing
          (setvar "ATTDIA" ATTDIA)
          (entupd (entlast))
    ;      (command "._DDATTE" (entlast))
          (princ)
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2001-03
    Tallahassee, FL
    3,272
    Sorry, that displays WCS not UCS.
    2011-09
    298
    Bump...
    Anyone figured this out? Fields with UCS coords rather than WCS?
    Any guidance is appreciated.
    James Pertusi
    1 (646) 773 4834
    2001-03
    Tallahassee, FL
    3,272
    If you wblock entire drawing the current UCS will be the world UCS in the new drawing.
    Might help for a workaround.
  1. Field shows different coordinates than actual point
    By crullier in forum AutoCAD Fields
    Last Post: 2015-07-31, 10:20 PM
  2. 2013: How do I export to IFC with project coordinates and not real world coordinates?
    By m.knutsson in forum Revit Architecture - General
    Last Post: 2013-10-15, 06:54 AM
  3. Attribute Extraction relative to current (not World) ucs
    By J17 in forum CAD Management - General
    Last Post: 2008-10-29, 04:18 PM
  4. Replies: 0
    Last Post: 2007-09-30, 02:56 PM
  5. Field for coords relative to current UCS
    Last Post: 2006-02-10, 11:52 PM
