I have Drop-downs in the Ribbon for both Copy and Paste that include the additional macros:
Command Name: Copy with 0,0 as Base Point
Description: Duplicates objects with 0,0 as the base point
Macro:
$M=$(if,$(eq,$(substr,$(getvar,cmdnames),1,8),GRIP),_copybase,^C^C_copybase) 0,0
Using the image RCDATA_16_ID
Command Name: Paste as Group
Description: Pastes objects from the Clipboard into the current drawing as a group
Macro:
^C^C_pasteblock;\(setq LstBlk(vla-get-Name (vlax-ename->vla-object (entlast))));_explode;_last;_-group;_create;*;;_previous;;(command "-purge" "B" LstBlk "N") (setq LstBlk nil)
(you must add a space after lisp in a macro)
Using the new group image RCDATA_16_NEWGROUP
I like being able to select everything I just inserted with one click. I've got 2012 thru 2015 installed and it works the same on all of them.
