Results 1 to 6 of 6
Thread: Hatch Patterns
    2004-07
    Baton Rouge, Louisiana
    254
    Default Hatch Patterns
    how do I get a custom hatch pattern to show up in the hatch dialog box. I have put the pattern in the directory that autocad help says to do, still no pattern in the dialog box. autocad was much simpler pre windows day.
    Earth
    9,831
    Default Re: Hatch Patterns
    Quote Originally Posted by vtmiii View Post
    When you say "no pattern in the dialog box", where are you looking? If they are in the support file search path, and the PAT file is valid, meaning no syntax errors, then they will show up here:
    R.K. McSwain | CAD Panacea |
    2004-07
    254
    I have added the pattern to acadhatch.pat file. are you suggesting I do it the patterns as their own file
    Cairo - no, not Illinois
    5,070
    generally that's a more useful way to handle custom hatch patterns. Each hatch is in its own file
    2009-11
    5,773
    1+
    This method also makes it more efficient when loading them on-demand, as opposed to loading an entire 'library' of patterns contained within a single file. Lee has a 'steal' routine, which can be quite useful as well.
    Cheers
    Computer Specs:
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
    2004-07
    254
    I have figured it out. come to find out that the hatch pattern I downloaded has an error in it. we need wood hatch patterns for doing sections for platforms that HVAC units sit on in our details
  1. 2015: create/ convert hatch patterns (.pat) to revit fill patterns
    By jledgewood in forum Revit Architecture - Tips & Tricks
    Last Post: 2015-06-01, 11:48 PM
  2. Replies: 5
    Last Post: 2008-03-16, 07:00 AM
  3. New Hatch Patterns
    By Clyne Curtis in forum Revit Architecture - General
    Last Post: 2006-05-26, 01:51 PM
  4. Hatch Patterns
    By bweir in forum Inventor - General
    Last Post: 2005-08-22, 03:22 PM
  5. Hatch Patterns
    By SCROSLEY in forum AutoCAD General
    Last Post: 2005-03-28, 11:42 PM
