Good day!
I am having a problem with the file I am work on. Xrefs are not found or unrefered.
Kindly help me on this.
Thanks you in advance
Good day!
That would be a file management issue. You can also check the stand alone Reference Manager, which is installed with AutoCAD, to adjust file paths.
Okay... your path is not correct, or the child files were moved, or your permissions are not correct, or.... it could be many things.
But overall, AutoCAD (more specifically, the O/S) cannot find the files once linked to this DWG.
R.K. McSwain | CAD Panacea |
Thank you for your respond.
I will try to look for its original xrefs location.
