Thread: Change Table Properties Using Lisp Routine
    2015-09
    420
    Default Change Table Properties Using Lisp Routine
    Hi AUGI Members,
    Is there a way to change the Cell Height, Vertical Cell Margin, Horizontal Cell Margin, & Cell Style using a lisp routine....?? When I Copy / Paste an Excel sheet into an AutoCAD Table using the Paste Special option the resulting table needs to be modified to conform to our standards even though I have a Table Style defined before I perform the Paste Special operation.
    Any help would be appreciated....!!
    Regards,
    Vince
    2023-07
    4
    Default Re: Change Table Properties Using Lisp Routine
    Quote Originally Posted by CADdancer View Post
    Hi AUGI Members,
    Regards,
    Vince
    Did you happen figure out a way?
    I'm working on a similiar issue.
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    Quote Originally Posted by druohonen796719 View Post
    Yes. It is possible to modify AutoCAD Tables using AutoLISP. You'll probably need to work through each individual cell. You can review the methods and properties available for table objects.
    6,409
    If PASTESPECMODE is set to 1, then set it to 0. Note that AutoCAD tables don't have ALL the formatting options that Excel does, so it may not look exactly like your Excel table.
    LinkedIn
  1. Need lisp routine to reverse bearings in line table
    By TRENA680153 in forum AutoLISP
    Last Post: 2015-04-23, 07:30 PM
  2. Curve Table Lisp Routine
    By julie.206712 in forum AutoLISP
    Last Post: 2013-08-20, 02:40 PM
  3. Help with this color change LISP routine
    By jeff.richards in forum AutoLISP
    Last Post: 2008-11-26, 02:54 PM
  4. Change Dynamic Properties of a DB in a Table
    Last Post: 2008-06-05, 02:15 PM
  5. Replies: 2
    Last Post: 2006-03-29, 03:42 PM
