Results 1 to 10 of 14
Thread: Control how far Zoom command will zoom out?
    2009-10
    262
    Default Control how far Zoom command will zoom out?
    How can I control how far autocad is willing to zoom out?
    I can do zoom extents to see all contents but I feel there should be a way that I can zoom out as far as I want, or adjust the distance it allows me to zoom out...
    2009-10
    262
    Default Re: Control how far Zoom command will zoom out?
    I know zoom factor controls the speed it zooms through the increments...but how can I control the increments it extends to?
    Cairo - no, not Illinois
    4,761
    I'm not sure I'm following what you think the problem is... the simplest way to control zooming out is by typing in the zoom factor, eg
    ZOOM
    0.05X
    or, to go out as far as there are drawing objects, ZOOM E
    2001-03
    Tallahassee, FL
    3,252
    Zoom 0.95XP to zoom out a little bit.
    I usually select the objects I need to be able to see and Zoom Object, scrolling out with the mouse first if necessary.
    Like cadtag it's hard to know how far out you want to zoom.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    4,761
    Quote Originally Posted by mbrandt5 View Post
    The old Solar System drawing would let you zoom from tight enough to read the moon landing plaque to out to the orbit of the (former) planet pluto. It's hard to think of construction drawings that call more zooming out than that.....
    2009-10
    262
    The reason I ask is because if you have a very complex dynamic block and zoom extent or zoom all it takes awhile to load...
    The commands you voiced to me are zooming in not out...
    Also when I am zooming out with the mouse wheel it stops at a certain distance I would like to stop that block from occuring
    2009-10
    262
    the view height and width to be exact...are zooming out to around 2500 by 3000...
    around 2000' further then the zoom extents of the objects in the drawing
    2001-03
    Tallahassee, FL
    3,252
    Zoom 0.95XP will zoom out a little bit, Zoom 0.5XP will zoom out a lot.
    For what you need just do a Zoom Object on the block.
    2001-03
    Tallahassee, FL
    3,252
    On both the Zoom flyout from the View menu and the Extents dropdown of the Navigate panel of the View tab on the Ribbon should be a zoom Out option whose macro is '_zoom .5x
    For what you need just do a Zoom Object (also found same places as Zoom Out in both the menu and Ribbon) on the block is your best option though.
    4,761
    The Zoom #X will zoom either in or out. the number (#) is zoom factor that is used to multiply the current scale leaving the viewcenter alone. numbers less than ONE zoom out, numbers greater than ONE zoom in.
    If the zoom window is exact, and repeatable, either define a VIEW than you can restore, or set up a macro that does a Zoom W (your minimum X,Y) (your maximum X,Y)
  1. Zoom control in and out of Orbit command
    Last Post: 2012-11-13, 06:15 PM
  2. Viewport Scale Control Update During Zoom Command
    By IanR in forum AutoCAD Wish List
    Last Post: 2010-06-09, 06:19 PM
  3. mouse zoom vs toolbar zoom onselectionchanged event
    By hastin_m in forum MapGuide - General
    Last Post: 2008-04-24, 03:13 PM
  4. Performance issues - Slow Zoom when using the Zoom command
    By gsmith.29521 in forum AutoCAD General
    Last Post: 2005-11-01, 08:53 PM
  5. ucsfollow zoom rotates view without zoom extents
    By dbroad in forum AutoCAD Wish List
    Last Post: 2004-10-05, 06:21 PM
