Results 1 to 8 of 8
Thread: Detail Bubble
    I could stop if I wanted to Cathy Hadley's Avatar
    2003-05
    San Diego
    222
    Default
    I'd like to create a detail bubble that is essentially a callout - that will reference a Drafting view -
    I would like the detail head to be as it is in the default callout however I want it to draw a line with a wide part at the bottom - similar to to section as if the tail pointed straight down.
    It seems so basic, yet I don't find one available... (maybe I'm not looking in the correct location)
    Thanks in advance - oh great Revit Guru's
    2003-05
    5,153
    Default Re: Detail Bubble
    You can swap the callout head for other types available in the annotations family or you can make a new callout head using the generic annotation template.
    There may be some on RUGI also.
    100 Club J-G's Avatar
    2003-04
    181
    You need to define a new family and set the family category to "Section Heads". Then in your project create a new section type called "call out," and use the new family as the section head. I attached the family so you just need to import it into your project and create a new section type.
    2003-05
    San Diego
    222
    Thanks guys, but the part I was really looking for wasn't about the section head... it was more about having a straight line with a tail that doesn't point to the side but straight down...
    I have found one way which is to use the callout and just make the rectangle very small to create your tail if you will, and then change the line weight...
    How are others handling this very basic look?
    Revit Guru gregcashen's Avatar
    2003-05
    Emeryville, CA
    1,352
    I have never done thnis, but I think your method is the easiest way to go. That sounds like how I would do it.
    All AUGI, all the time ajayholland's Avatar
    2003-04
    Sunny Southern California
    505
    Instead of the callout use a section marker and reference the drafting view. Load the section head you prefer. Edit the section marker properties, and reverse the values for tail length and width.
    -AJH
    2003-05
    San Diego
    222
    Thanks...
    I'll use the section way if I want the detail to show up on more than one view and the callout way if it only shows on in one!
    Thanks !!
    2003-04
    505
    Good Idea.
    (Wishlist) An option to display a new section only in the current view.
    -AJH
  1. Detail Bubble Problems
    By Arkman in forum Revit Architecture - General
    Last Post: 2010-07-30, 05:29 PM
  2. Dynamic Detail Bubble
    By mboyer in forum Dynamic Blocks - Sharing
    Last Post: 2009-09-30, 01:09 PM
  3. Detail Callout without bubble
    By tknapp in forum Revit - Platform
    Last Post: 2008-09-04, 01:17 PM
  4. Detail bubble
    By Maximillian in forum Revit Architecture - General
    Last Post: 2007-04-24, 09:00 AM
  5. Creating a Detail Bubble routine
    By dhurtubise in forum AutoLISP
    Last Post: 2006-05-08, 07:57 PM
