Thread: text style/stacked fractions in fields Acfield.fdc
    2009-10
    262
    Default text style/stacked fractions in fields Acfield.fdc
    I'm not sure this is the appropriate from but, I'd like to be able to get a text style used for fields.
    I'd also like to be able to stack fractions in autocad fields.
    What code would i edit in the file ACfield.fdc?
    From what i read its written in XML but there is no XML help here and, since it may be autocad specific I didn't know if someone at an xml help site could actually help...
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,652
    Default Re: text style/stacked fractions in fields Acfield.fdc
    Fields allow us to reference drawing information inside text, mtext or attributes. The text, mtext or attributes have text styles assigned to them not the fields as far as I know. What is it you're trying to do? You may have better luck on the AutoCAD Fields Forum: http://forums.augi.com/forumdisplay....AutoCAD-Fields
    2009-10
    262
    I have dynamic blocks that would save our company an immense amount of time by filling fields with lookup table values...
    But I would have to change the whole companies standard in order to use these dynamic blocks...
    I'd guess this applies to companies worldwide as well...
    I will post this to the field forum as well, thanks for the suggestion
    2017-11
    5
    YES PLEASE!!!! I am trying to do the same thing...have you ever gotten a response or found a way to do this?
  1. 2014: Converting all fractions in all text selected to stacked fractions
    By mbrandt5 in forum AutoCAD General
    Last Post: 2015-06-10, 09:42 PM
  2. text style/stacked fractions
    By mbrandt5 in forum AutoCAD Fields
    Last Post: 2015-05-09, 10:20 PM
  3. Stacked fractions in Text Notes?
    By MooksBK in forum Revit Architecture - General
    Last Post: 2014-05-15, 02:29 PM
  4. Stacked Fractions in text and dimensions
    By raddis in forum Revit Architecture - Wish List
    Last Post: 2012-06-06, 05:08 PM
  5. Stacked fractions in attribute text
    By jsnow in forum AutoCAD General
    Last Post: 2005-12-06, 01:37 AM
