Results 1 to 7 of 7
Thread: 2013 Xref changes
    2002-07
    3
    Default 2013 Xref changes
    I have been supplied with a drawing which looks for an early xref Rev e. I have been supplied with a Rev h drawing.
    I cannot figure out how to alter the drawing to look and load this Rev h Xref.
    Help would be appreciated.
    By the way no Prefix drop down list on my screen!
    John Farrer
    2009-11
    5,585
    Default Re: 2013 Xref changes
    Quote Originally Posted by john.farrer View Post
    Welcome to AUGI.
    In the XREF Palette, you can change the reference's name and file path as needed, or simply detach the problem reference and attach the correct reference, so long as there are no layer settings you wish to retain.
    Cheers
    Computer Specs:
    Dell Precision 3630, Core i9-9900K 5.0GHz, 128GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2002-07
    3
    Thank you BlackBox,
    I have managed to LOAD the new Xref but the content is not displayed. The xef is shown as Loaded in the Xref listing, should it show as attached? I Reconciled all the layers. Could it be that the new xref is not attached at the correct point?
    John Farrer
    2009-11
    5,585
    Thank you BlackBox,
    A quick Zoom Extents *should* answer that... Could the XREF be on a frozen/off layer? In Layer Manager, are all/any XREF-specific layers thawed/on?
    Cheers
    Computer Specs:
    Cairo - no, not Illinois
    4,897
    you should also check the value of INSBASE in both the original, and replacement xref files. Are they the same? Is the coordinate value of the objects in the Xref the same?
    2009-11
    5,585
    Also, FWIW -
    I started using this recently... Large 3-phase development, with a separate roadway improvement/water main extension sub-project, that was originally in one project folder structure, and naming convention, until we recently changed the entire setup of both (again; grrr)... And Tim's work was a lifesaver:
    ... Just needed to compile for 2015-2016, and redo some layer states.
    Cheers
    Computer Specs:
    2002-07
    3
    No luck with this. Also INSBASE is 0,0,0 on both Xref files.
    I have now overcome the problem by renaming the Rev h xref file to Rev e.
    I will have to sort this out eventually.
    Many thanks John
  1. Exportar Revit 2012-2013 a 3ds Max Design 2013...
    By magdagarciavinuesa in forum Español - Revit
    Last Post: 2015-02-04, 10:34 PM
  2. 2013 Objects From Revit MEP 2013 Missing in Navis Manage 2013
    By MetalliCAD in forum NavisWorks - General
    Last Post: 2013-03-05, 08:52 PM
  3. Revit 2013 Detail Views Showing up in Navisworks 2013
    By tfullerpipes in forum NavisWorks - General
    Last Post: 2013-01-30, 07:37 AM
  4. 2013 doesnt refresh the xref's
    By drewj in forum NavisWorks - General
    Last Post: 2012-06-07, 11:11 PM
  5. 2008 SCALE 1:100 xref xref xref xref- scale list issues
    By Apsis0215 in forum AutoCAD Customization
    Last Post: 2008-11-21, 08:17 PM
