Thread: grading objects that work
    Wish List Administration
    2011-08
    4,581
    Default grading objects that work
    Summary: Grading objects in LDD were more user friendly easier to edit. they had grips you could move them, specify corners better.
    Description: Need a grading object that is easier to edit and actually works. Civil3d doesn't transition between different region well at all and results are unreliable at best and usually erratic.
    Product and Feature: AutoCAD Civil 3D - Grading
    Submitted By: Remi Fritz on 05/12/2015
    2009-11
    5,771
    Default Re: grading objects that work
    Quote Originally Posted by Wish List System View Post
    Not being sure of the exact application you're attempting to grade, and not necessarily disagreeing with you, just wanted to offer that I generally use Feature Lines as surface breaklines rather than grading objects, as they're easier to manage, can be offset (horiz, vert), etc.
    Cheers
    Computer Specs:
    Dell Precision 5860, Xeon W7-2495X, 128GB RAM, Dual PCIe 4.0 M.2 SSD (RAID 0), 20GB NVIDIA RTX 4000 ADA
  1. Why does grading not always work?
    By jtgb in forum AutoCAD Civil 3D - Grading
    Last Post: 2007-11-16, 11:36 PM
  2. Can you get grading to work?
    By bijold in forum AutoCAD Civil 3D - Grading
    Last Post: 2007-06-06, 12:48 AM
  3. Grading Objects
    By DanielW in forum Civil 3D - Civil Design Companion - General
    Last Post: 2006-11-14, 08:07 PM
