Thread: Inventor 2016
    2015-05
    Default Inventor 2016
    I noticed after installing 2016 inventor, all the other versions of inventor are still on this computer, 2013,2014,2015. Should I be Un-Installing these older versions?
    Earth
    9,772
    Default Re: Inventor 2016
    I'm not an Inventor expert, but if it's like most other Autodesk products, they can be installed side-by-side and installing a new version does not remove older versions.
    R.K. McSwain | CAD Panacea |
    Cairo - no, not Illinois
    4,822
    2
    If you don't need the older versions for any reason, and decide to un-install them, it's probably a good idea to do a re-install or repair of the ones you keep. Do the repair in order, (if deleting 2013 & 2014, repair 2015, test it, then repair 2016) and you should be good to go.
    100 Club reikajapan's Avatar
    2007-11
    102
    From a licensing stand point, if you are on subscription then you are ok, if not then the others are supposed to be removed, IIRC.
  1. [3dsmax 2016 - Maya 2016] Extension 1
    By METANAMORPHOSE in forum Français - 3ds Max / Maya
    Last Post: 2015-08-13, 11:47 AM
  2. 2016: Publish command is slow to open in AutoCAD 2016 & AutoCAD 2016 LT
    By leinsterlady in forum AutoCAD Plotting
    Last Post: 2015-07-14, 07:42 PM
  3. 2016: Add-Ins 2016
    By mit81 in forum Revit MEP - General
    Last Post: 2015-07-02, 08:54 AM
  4. 3dsmax 2016 / maya 2016
    Last Post: 2015-04-15, 09:58 AM
  5. 2016: What news.... in 2016 ...
    By cnevians@yahoo.fr in forum Revit Architecture - Général
    Last Post: 2015-04-13, 03:20 PM
