Can i make a variable set based upon a select using this code or something similar
(setq X (getkword "\nWhat should X equal? [Time,Money,Help] :"))
Sorry for any syntax errors; posting from an iPhone:
Code:(if (and (not (initget "Time Money Help")) (setq X (getkword "\nWhat should \"X\" equal? [Time,Money,Help] :")) ) (prompt (strcat "\nYou entered \"" X "\" for the value of \"X\" ")) )
Computer Specs:
Another question...the X variable needs to interact with other instances there for the variable must show the whole word.
Is there a way I can do this with getstring without entering the whole word...
So If I have (setq X (getstring "\nWhat should X equal? [Time,Money,Help] : "))
If i enter just H for Help it sets X's string equal to H in other references of X in a code.
Can I make that string = Help without entering the whole word
Maybe with something like Y=X string based on the letter entered, then having Y reference the rest of the code.
Also how did you encapsulate your code in your post?
Try adding a CONDitional statement:
Code:(if (and (not (initget "Time Money Help")) (setq X (getkword "\nWhat should \"X\" equal? [Time,Money,Help] :")) (setq X (strcase X)) ) (prompt (strcat "\nYou entered \"" (cond ((wcmatch X "T*") "Time") ((wcmatch X "M*") "Money") ((wcmatch X "H*") "Help") ) "\" for the value of \"X\" " ) ) )
Also, see posting guidelines for use of [ CODE ] tags; posting from mobile, so sorry for not providing direct link. You can quote my post to see more.
Cheers
Computer Specs:
Any ideas why this isn't continuing after value of x is returned?Code:(defun C:Test (/ kw X) (while (and (not (initget 7 "Yes No")) (setq kw (getkword "\nDefine X? [Yes,No] :")) (eq kw "Yes") (if (and(not (initget "Time Money Help")) (setq X (getstring "\nWhat should \"X\" equal? [Time,Money,Help] :")) (setq X (strcase X)) ) (prompt (strcat "\nYou entered \"" (cond ((wcmatch X "T*") "Time") ((wcmatch X "M*") "Money") ((wcmatch X "H*") "Help") ) "\" for the value of \"X\" " ) ) ) ) ) )
I apologize for the lack of bracket spacing...I just can't seem to find how to enclose my code
I'll let you identify the difference in code logic:
Code:(defun C:Test (/ kw X) (while (and (not (initget 7 "Yes No")) (setq kw (getkword "\nDefine X? [Yes,No] :")) (eq kw "Yes") ) (if (and (not (initget "Time Money Help")) (setq X (getstring "\nWhat should \"X\" equal? [Time,Money,Help] :" ) ) (setq X (strcase X)) ) (prompt (strcat "\nYou entered \"" (cond ((wcmatch X "T*") "Time") ((wcmatch X "M*") "Money") ((wcmatch X "H*") "Help") ) "\" for the value of \"X\" " ) ) ) ) )
No worries; we all start somewhere... This should help:
http://forums.augi.com/misc.php?do=bbcode
Computer Specs:
Computer Specs:
How can I repeat the same results with a response of same results...
I don't just want the results to be displayed again but actually stored and reentered essentially
So I'd define x, define y then be prompted to repeat same results and the definitions would be once again defined as the original input string
Code:(defun C:Test (/ kw X) (while (and (not (initget 7 "Yes No")) (setq kw (getkword "\nDefine X? [Yes,No] :")) (eq kw "Yes") ) (if (and (not (initget "Time Money Help")) (setq X (getstring "\nWhat should \"X\" equal? [Time,Money,Help] :" ) ) (setq X (strcase X)) ) (prompt (strcat "\nYou entered \"" (cond ((wcmatch X "T*") "Time") ((wcmatch X "M*") "Money") ((wcmatch X "H*") "Help") ) "\" for the value of \"X\" " ) ) ) (if (and (not (initget "Time Money Help")) (setq Y (getstring "\nWhat should \"Y\" equal? [Time,Money,Help] :" ) ) (setq Y (strcase Y)) ) (prompt (strcat "\nYou entered \"" (cond ((wcmatch Y "T*") "Time") ((wcmatch Y "M*") "Money") ((wcmatch Y "H*") "Help") ) "\" for the value of \"Y\" " ) ) ) ) )
I'm not entirely sure that I understand what you're asking; perhaps you could clarify?
In any event, here's a quick stab in the dark:
Code:(defun c:FOO (/ _GetValue kw x y) (defun _GetValue (x) (cond ((wcmatch x "T*") "Time") ((wcmatch x "M*") "Money") ((wcmatch x "H*") "Help") ) ) (while (and (not (initget 7 "Yes No")) (setq kw (getkword "\nDefine X? [Yes/No] :")) (eq kw "Yes") ) (if (and (or *Option1* (setq *Option1* "Time") ) (not (initget "Time Money Help")) (or (/= "" (setq x (getstring (strcat "\nWhat should \"X\" equal? [Time/Money/Help] " (if *Option1* (strcat "<" *Option1* ">: ") ": " ) ) ) ) ) (setq x *Option1*) ) (setq *Option1* x) ) (prompt (strcat "\nYou entered \"" (_GetValue x) "\" for the value of \"X\" " ) ) ) (if (and (or *Option2* (setq *Option2* *Option1*) ) (not (initget "Time Money Help")) (or (/= "" (setq y (getstring (strcat "\nWhat should \"Y\" equal? [Time/Money/Help] " (if *Option2* (strcat "<" *Option2* ">: ") ": " ) ) ) ) ) (setq y *Option2*) ) (setq *Option2* y) ) (prompt (strcat "\nYou entered \"" (_GetValue y) "\" for the value of \"Y\" " ) ) ) ) )
Computer Specs:
