Thread: ObjectARX AUTOCAD 2013 - VisualStudioExpress 2010
    2015-05
    3
    Default ObjectARX AUTOCAD 2013 - VisualStudioExpress 2010
    Ciao a tutti,
    sto provando a scrivere un' applicazione per leggere blocchi da disegni autocad ed importarli nel disegno corrente.
    Non riesco a capire il motivo dell' errore nella funzione di Insert:
            <Autodesk.AutoCAD.Runtime.CommandMethod("INSERISCI")> _
            Public Shared Sub Inserisci()
                Dim tDoc As ApplicationServices.Document = ApplicationServices.Application.DocumentManager.MdiActiveDocument
                Dim tDocDB As DatabaseServices.Database = tDoc.Database
                Dim tDocLock As ApplicationServices.DocumentLock = Nothing
                Dim tTrAct As DatabaseServices.Transaction = Nothing
                Dim tDwgFileName As String = "C:\Users\UTENTE\Documents\VB.NET\HelloWorld\test1.dwg"
                Dim tBlockName As String = "test1"
                Dim tBlTabRecID As ObjectId = Nothing
                Dim tDB As DatabaseServices.Database = Nothing
                Try
                    If IO.File.Exists(tDwgFileName) Then
                        tDocLock = tDoc.LockDocument
                        tTrAct = tDoc.TransactionManager.StartTransaction
                        tDB = New Database(False, True)
                        tDB.ReadDwgFile(tDwgFileName, IO.FileShare.None, True, "")
                        tDocDB.Insert(Matrix3d.Displacement(New Vector3d(0, 0, 0)), tDB, True) '<-------- OK!
                        'Errore!
                        tBlTabRecID = tDocDB.Insert(tBlockName, tDB, False) <------ Errore eSelfReference!
                        tTrAct.Commit()
                    Else
                        MsgBox("File: " & tDwgFileName & " could not be found!")
                    End If
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    MsgBox("ReadFromDWG:" & ex.Message & vbNewLine & ex.StackTrace)
                Finally
                    If tTrAct IsNot Nothing Then tTrAct.Dispose() : tTrAct = Nothing
                    If tDocLock IsNot Nothing Then tDocLock.Dispose() : tDocLock = Nothing
                End Try
            End Sub
    Cosa sbaglio??
    Grazie!
    Last edited by BlackBox; 2015-05-19 at 03:14 PM. Reason: Please use [CODE] Tags | Si prega di utilizzare i Tag [CODE]
    2009-11
    5,723
    Default Re: ObjectARX AUTOCAD 2013 - VisualStudioExpress 2010
    English (Google Translate):
    Quote Originally Posted by lucalenzi82701057 View Post
    Hello everyone,
    I'm trying to write an 'application to read blocks from AutoCAD drawings and import them into the current drawing.
    I can not understand the reason of 'error in the function Insert:
                Try
                        'Errore!
                        tTrAct.Commit()
                    Else
                    End If
                Finally
                End Try
            End Sub
    What is wrong ??
    Thanks!
    Computer Specs:
    2009-11
    5,723
    Consider the meaning of the Exception being raised, and note the name of both your source drawing (being opened as side Database), and the block you're attempting to Insert():
    [Google Translate] Si consideri il significato della eccezione sollevata, e prendere nota del nome del sia il vostro disegno di origine (come l'apertura del database lato), e il blocco che si sta tentando di inserire ():
                Try
                        'Errore!
                        tTrAct.Commit()
                    Else
                    End If
                Finally
                End Try
            End Sub
    That said, give this DevBlog article a read, and note the usage of WblockCloneObjects() instead of Insert() Method:
    [Google Translate] Detto questo, dare a questo articolo Devblog una lettura, e notare l'uso di WblockCloneObjects () al posto di Insert () Metodo:
    http://adndevblog.typepad.com/autoca...sing-net-.html
    Separatamente, dove in Italia si chiama a casa? Abbiamo famiglia lì; mia Nonna vive appena fuori Venezia!
    Ciao
    Computer Specs:
    2015-05
    3
    Hi, first of all thanks for your fast reply.
    I have discover so the mistake...I have change the blockname from:
    ...to
    Dim tBlockName As String = "test2"
    and it works.
    But I have seen that in block list I have both "test1" and "test2" with "DB.Insert" command.
    How to keep only one block, that read from dwg file?
    So, to insert an external drawing directly into the current drawing to I have to use matrix object, right?
    ...and to add a block read from an external drawing into blocklist do I have to use WblockCloneObjects, right?
    Thanks
    2009-11
    5,723
    You're welcome.
    ...to
    and it works.
    As I understand it (and I could be mistaken), Database.Insert() is only used to insert the entirety of another drawing into MdiActiveDocument (like the INSERT Command), or an existing BlockTableRecord within the current Database into same Database as BlockReference, etc.... Whereas Database.WblockCloneObjects() Method is used to 'copy' objects (and their BlockTableRecord[s], etc.) from one drawing to another (without INSERTing the entire source drawing).
    Here's another reference:
    http://through-the-interface.typepad..._blocks_f.html
    HTH (Hope This Helps)
    Computer Specs:
  1. 2013: Setting AutoCAD to always saveas 2010 file format using 2013
    By 3D Jack in forum AutoCAD for Mac General
    Last Post: 2013-11-02, 02:11 PM
  2. DE115-2: Ask the Experts: ObjectARX and AutoCAD .NET Panel Discussion
    Last Post: 2013-05-05, 01:43 PM
  3. Sharing files between Autocad 2013 LT and Autocad 2013
    By ksnyyfan2341090 in forum AutoCAD General
    Last Post: 2013-04-25, 01:25 AM
  4. AutoCAD, ObjectARX e AUGI
    By fpmalard in forum AutoLISP
    Last Post: 2007-05-18, 02:36 PM
Tags for this Thread
