Results 1 to 8 of 8
Thread: Extract a User Specified contour elevation from a surface
    Wish List Administration
    2011-08
    4,581
    Default Extract a User Specified contour elevation from a surface
    Summary: I would like a tool that allows us to specify a specific elevation and would then generate and extract that contour from a surface.
    Description: Several times I've needed to extract a very odd elevation from a surface to show in the plans, such as where a FEMA flood line, or top of water elevation sits on a surface. I've had to change the contour interval and go in and extract the elevation at say the closest 0.05 (as smaller intervals are generally too cumbersome to display).
    It would be easier to have a tool that lets me just input the elevation I need and then it can generate the contour line from the surface. Perhaps it could even add some tools to help weed/add curves to the resulting polyline.
    Product and Feature: AutoCAD Civil 3D - Surface Modeling
    Submitted By: Adam Reilly on 06/01/2015
    Earth
    9,804
    Default Re: Extract a User Specified contour elevation from a surface
    You can do that now.
    Surface Properties > Analysis tab > Add Contour Analysis.
    Say you want the 95.0' contour.
    Add a single range of 94.99 to 95.01
    Turn on User Contours in the surface style (and maybe change the color so it will stand out)
    After the contour(s) are displayed, run the command "_AeccSurfaceExtractObjects", uncheck everything except User Contours.
    The 95.0' contour is (or contour lines are) now polyline(s).
    R.K. McSwain | CAD Panacea |
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,100
    In that same tab, there is an option for the Analysis Type for User-defined contours. Add the appropriate number of ranges and click the Run Analysis button. If the elevations listed are not correct, edit the elevations as needed.
    Earth
    9,804
    Even better. Thanks, learned something myself today!
    2011-08
    4,581
    Exclamation Re: Extract a User Specified contour elevation from a surface
    2011-08
    4,581
    2011-08
    4,581
    2011-08
    4,581
  1. 2014: Surface Contour Problem
    By FBL - Desirea in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2013-11-27, 04:48 PM
  2. Can you Extract a point file from a Surface?
    By teamstp in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-01-08, 06:45 AM
  3. surface contour labels
    By jackland in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-06-22, 07:34 PM
  4. Extract Elevation Object Data and Assign to Polyline Contour
    By clarkl in forum AutoCAD Map 3D - General
    Last Post: 2009-04-01, 04:53 PM
