Results 1 to 8 of 8
Thread: Select the last N entities created in a lisp routine.
    I could stop if I wanted to jpcadconsulting347236's Avatar
    2011-09
    300
    Default Select the last N entities created in a lisp routine.
    OK gang, here's today's conundrum.
    I've got this lisp that draws a ramp tag and it works great:
    (defun c:ramp (/ arrow slopetext slopeorigin layorig usersnaps p1 p2 x1 x2 dist ang p3 angdeg)
    (setq arrow "slopearrow.dwg")
    (setq slopetext "slopevalue.dwg")
    (setq slopeorigin "slopeorigin.dwg")
    (setq layorig (getvar "clayer"))
    (setq p1 (getpoint "\npick high point of ramp: "))
    (setq p2 (getpoint "\npick low point of ramp: "))
    (setq x1 (car p1))
    (setq x2 (car p2))
    (setq dist (distance P1 P2))
    (setq ang (angle P1 P2))
    (setq p3 (POLAR P1 ANG (/ DIST 2)))
    (setq angdeg (* (/ ang pi) 180.0))
    (command "-layer" "Make" "L-GR-TEXT" "Color" "3" "L-GR-TEXT" "Ltype" "CONTINUOUS" "" "")(princ)
    (command "line" p1 p2 "")
    (command "-insert" slopeorigin P1 "1" "1" angdeg)
    (command "-insert" arrow p2 "1" "1" angdeg)
    (command "-insert" slopetext p3 "1" "1" angdeg)
    (if (> x1 x2) (command "rotate" "L" "" p3 "180")
    (setvar "clayer" layorig)
    (princ)
    Now I've been asked to have the routine to make an unnamed group from the objects it creates. So I have cobbled this together (added code in red):
    (defun c:ramp ( / arrow slopetext slopeorigin layorig usersnaps p1 p2 x1 x2 dist ang p3 angdeg ss lastEnt en)
    (setq lastEnt (entlast))
    (setq x1 (car p1))
    (setq x2 (car p2))
    (setq ss (ssadd))
       (if (setq en (entnext LastEnt)) ;Check if there's a new entity created sinse the last one
         (while en ;Step through all new entities
           (ssadd en ss) ;Add it to the selection set
           (setq en (entnext en)) ;Get the next entity
    (command "_.-group" "c" "*" "*" ss "")
    (princ)
    It does what it should the first time, it makes a group form the objects created in the routine.
    However, during subsequent runs, it makes a group of the objects created in the routine AND the last group created in the previous run. Obviously it should EXCLUDE the previous group and make the new group from only objects created SINCE last object was created.
    I'm missing something. Thanks for your help.
    I can't seem to upload files at the moment but Slopeorigin.dwg is just a circle, slopearrow.dwg is just an arrow made from 2 lines and slopevalue.dwg is just an atribute. You should be able substitue your own blocks easily. I'll keep trying.
    James Pertusi
    CAD Applications Consultant
    1 (646) 773 4834
    www.jpcadconsulting.com
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL
    3,403
    Default Re: Select the last N entities created in a lisp routine.
    Try moving
    down to just before
    to make sure (entnext LastEnt) is that line.
    Worked for me, but I don't have those drawings to test it completely.
    Tom Beauford P.S.M. - Civil 2020 on Windows 10 Enterprise
    Design Analysis - Leon County Public Works/Engineering Wrap [CODE] tags around selected text
    Ph# (850)606-1516 Home Page
    2011-09
    300
    Thanks Tom, I'll keep you posted!!
    James Pertusi
    1 (646) 773 4834
    2011-09
    300
    Try moving
    down to just before
    Well, it does the same thing. I think it has to do with this section later on in the routine:
    That line rotates the slope text depending on how you pick the points and it uses the "Last" object selection.
    James Pertusi
    1 (646) 773 4834
    2011-09
    300
    Eh... having second thoughts about it being that line. I now think its in the section of the code below. I think this for 2 reasons:
    1. This is the section that collects objects created SINCE Entlast
    2. I copied this from some other routine and I don't REALLY understand how it's working.
    (setq ss (ssadd))
      (if (setq en (entnext LastEnt)) ;Check if there's a new entity created since the last one
    James Pertusi
    1 (646) 773 4834
    2011-09
    300
    Well, I've got it working... but I'm not proud of how I did it. It seems clunky to me and I'm sure there is a more elegant way to accomplish it.
    The first thing it does is draw a point at 0,0 (which becomes the last entity)
    Then at the end of the command, it erases the point.
    It works, but you know... not a great solution. Plus if it fails for some reason, it's going to leave a point at 0,0. Meh. I give it a C-.
    (command "point" "0,0")
    (setq x1 (car p1))
    (setq x2 (car p2))
    (command "rotate" "L" "" p3 "0")
    (setq ss (ssadd))
    (command "erase" lastent "")
    (princ)
    James Pertusi
    1 (646) 773 4834
    All AUGI, all the time marko_ribar's Avatar
    2015-10
    Belgrade, Serbia, Europe
    557
    If it works fine, than this should work too (added error handler in case routine fails - it sets back sysvar clayer to original state and automatically removes dummy point)... You can study error handlers from www.lee-mac.com ... HTH, M.R.
    (defun c:ramp ( / *error* pt arrow slopetext slopeorigin layorig usersnaps p1 p2 x1 x2 dist ang p3 angdeg ss lastEnt en )
    (defun *error* ( msg )
    (if layorig (setvar 'clayer layorig))
    (if (and pt (entget pt)) (entdel pt))
    (if msg (prompt msg))
    (princ)
    ;;;(command "point" "0,0")
    (setq pt (entmakex (list '(0 . "POINT") (cons 10 (list 0.0 0.0 0.0)))))
    (setq x1 (car p1))
    (setq x2 (car p2))
    (setq ss (ssadd))
    ;;;(command "erase" lastent "")
    ;;;(setvar "clayer" layorig)
    ;;;(princ)
    (*error* nil)
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on Youtube
    2011-09
    300
    Works great Marko!! Thanks for your hard work.
    Now I just need to stare at it for an hour and figure out WHY it works.
    And yeah... Lee Mac is the man.
    James Pertusi
    1 (646) 773 4834
  1. Replies: 8
    Last Post: 2016-01-22, 01:38 PM
  2. Looking for lisp routine to select objects inside polyline
    By vlad_tzok133583 in forum AutoLISP
    Last Post: 2011-05-16, 02:02 AM
  3. LISP CHALLENGE - symbols created within routine
    By bowlingbrad in forum AutoLISP
    Last Post: 2008-12-23, 07:40 PM
  4. Create a Selection Set of Entities as They are Created
    Last Post: 2008-10-12, 06:37 PM
  5. Can't select entities
    By jpaulsen in forum AutoCAD General
    Last Post: 2007-04-19, 03:20 PM
